How do I access my VME hardware from MVME3100?: revised
rtwas
rtwas at comcast.net
Fri Jan 29 00:12:20 UTC 2010
I forgot the pointer value assignment
rtwas wrote:
> rtwas wrote:
> > Dimitrios Tsifakis wrote:
> >> Hello everyone,
> >> I am a new RTEMS user. I have just managed to compile 4.9.3 for
> >> an MVME3100 and run the hello_world_c program. The second step I
> >> had in mind was to access the VME cards that are also installed
> >> in that crate, but I cannot find any documentation that describes
> >> how to achieve that.
> >> Any help and pointing to the right direction would be greatly
> >> appreciated.
> >> Regards Dimitris
> > Hello,
> > My understanding is that the mvme ppc bsp's use the motorola setup
> > defaults for each of the address space types (32bit (extended),
> > 24bit (standard), 16 (short io)). The BSP_vme2local_adrs()
> > function (according to Till) just does a verification of an
> > existing mapping.
> > " This function doesn't do any mapping but it checks if the given
> > local address is mapped on the VME bus ('visible to other VME
> > masters') using already existing mappings and translates it into a
> > VME address. " -Till Strauman
> > You need to use a "BSP" function, here's a 24bit (Standard)
> > address space example:
> > unsigned long local_address; volatile uint32_t * vme32p;
> > return = BSP_vme2local_adrs(VME_AM_STD_SUP_DATA, 0x00000000,
> > &local_address); // map the space
> > if(return <0) printf("BSP_vme2local_adrs(): failed \n");
> > else
> >// to access address 0x1000
> > { vme32p = (uint32_t *) local_address; // <---forgot this part
> > *(vme32p + 0x1000/4) = 0xdeadbeef; //
> > } for a 32 bit word write
> > // the "/4" thing is there because the address space is in *bytes*
> > but the pointer // is 4 times that size.
> >The "am" codes can be found:
> > "/opt/rtems-4.9/powerpc-rtems4.9/mvme5500/lib/include/bs/vme_am_defs.h"
> > (in the case of an mvme5500 on a Linux system install)
> > -or- "./c/src/lib/libbsp/shared/vmeUniverse/vme_am_defs.h"
> > The relevant BSP functions can be found:
> > "c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c"
> > If your write/read *order* is important you'd probably want to do
> > an *inline* "eieio" instruction to force "in order execution".
> > There was talk in one of the past emails about using some io
> > functions to do this but I've not located them yet.
> > I asked this question not long ago. You should be able to find it
> > in the email archives.
> > Robert W.
