ARM compiler error when building RTEMS for smdk2410
Ajai James
ajai at sigtechwireless.com
Fri Jul 9 11:08:30 UTC 2010
Hi All,
I am a newbie in RTEMS and Linux environment.
I was trying to compile RTEMS for ARM smdk2410 board using Fedora guest in
Virtual box with command
make RTEMS_BSP="smdk2410" after configure command as per the steps in
http://rtems.org/onlinedocs/doc-current/share/rtems/html/started/started0006
1.html
Got an error as below
Checking whether the C compiler works... no
configure: error: in
`/home/rtems/rtems-4.10-work/rtems/build-rtems/arm-rtems4.10/c/smdk2410':
configure: error: C compiler cannot create executables
See `config.log' for more details.
gmake[2]: *** [smdk2410] Error 1
gmake[2]: Leaving directory
`/home/rtems/rtems-4.10-work/rtems/build-rtems/arm-rtems4.10/c'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
make: *** [all-recursive] Error 1
On checking the config.log file, the relevant portion is
gmake[3]: Entering directory
gmake[3]: Leaving directory
checking for RTEMS_CPU_MODEL... s3c2410
checking for RTEMS_BSP_FAMILY... smdk2410
checking for CPU_CFLAGS... (cached) -mstructure-size-boundary=32
-mcpu=arm920t -mfpu=vfp -mfloat-abi=soft -DCPU_S3C2410
checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
checking for style of include used by gmake... GNU
checking for arm-rtems4.10-gcc... arm-rtems4.10-gcc
checking for arm-rtems4.10-gcc... (cached) arm-rtems4.10-gcc
checking whether the C compiler works... no
Pls help
Regards,
Ajai James
URL: <http://lists.rtems.org/pipermail/users/attachments/20100709/937ca2ed/attachment.html>
