Access my local files using RTEMS
Vinu Rajashekhar
vinutheraj at gmail.com
Sat Jul 10 23:32:44 UTC 2010
On Sun, Jul 11, 2010 at 4:01 AM, Vinu Rajashekhar <vinutheraj at gmail.com>wrote:
> I was wondering whether there is some way through
> which I could access my local files using RTEMS,
> running on qemu ?
> I tried running the fileio test in samples using the pc386
> test script, but my local files do not seem to be affected.
> I changed the config from IMFS to RFS, by the way,
> before running the test.
Yes, I am able to access my local files using the technique
in fileio + pc386 script.
If you want to modify your local files you have to change the
fat: option in pc386 to fat:rw:
URL: <http://lists.rtems.org/pipermail/users/attachments/20100711/36a48d22/attachment.html>
