Access my local files using RTEMS
Vinu Rajashekhar
vinutheraj at gmail.com
Sun Jul 11 13:48:31 UTC 2010
I have a follow-up question based on this.
I could access my local files using pc386
script and qemu -hda fat: option.
Similarly, does all the other targets also support
something like this, if the simulator is not qemu ?
On Sun, Jul 11, 2010 at 5:06 AM, Vinu Rajashekhar <vinutheraj at gmail.com>wrote:
> On Sun, Jul 11, 2010 at 5:02 AM, Vinu Rajashekhar <vinutheraj at gmail.com>wrote:
>> On Sun, Jul 11, 2010 at 4:01 AM, Vinu Rajashekhar <vinutheraj at gmail.com>wrote:
>>> I was wondering whether there is some way through
>>> which I could access my local files using RTEMS,
>>> running on qemu ?
>>> I tried running the fileio test in samples using the pc386
>>> test script, but my local files do not seem to be affected.
>>> I changed the config from IMFS to RFS, by the way,
>>> before running the test.
>> Yes, I am able to access my local files using the technique
>> in fileio + pc386 script.
>> If you want to modify your local files you have to change the
>> fat: option in pc386 to fat:rw:
> Additionally, I had to add a config option
> CONFIGURE_FILESYSTEM_DOSFS too to make this work.
> If anybody knows of any easier way to do this, please
> do reply.
URL: <http://lists.rtems.org/pipermail/users/attachments/20100711/e940224a/attachment.html>
