ARM compiler error when building RTEMS for smdk2410
Vinu Rajashekhar
vinutheraj at gmail.com
Tue Jul 13 15:37:03 UTC 2010
On Fri, Jul 9, 2010 at 4:38 PM, Ajai James <ajai at sigtechwireless.com> wrote:
> Hi All,
> I am a newbie in RTEMS and Linux environment.
> I was trying to compile RTEMS for ARM smdk2410 board using Fedora guest in
> Virtual box with command
> make RTEMS_BSP="smdk2410" after configure command as per the steps in
> http://rtems.org/onlinedocs/doc-current/share/rtems/html/started/started00061.html
> Got an error as below
> Checking whether the C compiler works... no
> configure: error: in
> `/home/rtems/rtems-4.10-work/rtems/build-rtems/arm-rtems4.10/c/smdk2410':
> configure: error: C compiler cannot create executables
> See `config.log' for more details.
> gmake[2]: *** [smdk2410] Error 1
> gmake[2]: Leaving directory
> `/home/rtems/rtems-4.10-work/rtems/build-rtems/arm-rtems4.10/c'
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory
> make: *** [all-recursive] Error 1
> On checking the config.log file, the relevant portion is
That is the config.log in the top directory, I think you will get more
specific details
on the error if you check the config.log in
'/home/rtems/rtems-4.10-work/rtems/build-rtems/arm-rtems4.10/c'
> gmake[3]: Entering directory
> gmake[3]: Leaving directory
> checking for RTEMS_CPU_MODEL... s3c2410
> checking for RTEMS_BSP_FAMILY... smdk2410
> checking for CPU_CFLAGS... (cached) -mstructure-size-boundary=32
> -mcpu=arm920t -mfpu=vfp -mfloat-abi=soft -DCPU_S3C2410
> checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
> checking for style of include used by gmake... GNU
> checking for arm-rtems4.10-gcc... arm-rtems4.10-gcc
> checking for arm-rtems4.10-gcc... (cached) arm-rtems4.10-gcc
> checking whether the C compiler works... no
> Pls help
> Regards,
> Ajai James
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100713/52a40110/attachment.html>
