RTEMS (+epics) on a mvme167: Problems with environ
Jan C. Bernauer bernauer at mit.edu
Fri Jul 16 15:19:16 UTC 2010
  Hi,
  I am struggling to get RTEMS+EPICS working on an mvme167 (m68k based
vme cpu).
Tools are installed, and the test programs I tried seem to work.
However, trying to run rtemsTestHarness from EPICS fails when strncmp
tries to access a null pointer.
I traced it back to setenv: A test program with the rtems shell also
fails on setenv.
As far as I see, the environ pointer is 0.
How should the BSP set this up? Just malloc a block of memory at init time?
Best regards,
Jan C. Bernauer
