Issue regarding rtems_libio_share_private_env under libcsupport
Bharath Suri
bharath.s.jois at gmail.com
Sat Jul 17 14:48:46 UTC 2010
Hi,
I am summing up the PR 1620
(https://www.rtems.org/bugzilla/show_bug.cgi?id=1620) in this mail.
The calling task needs to get the private environment of the task,
whose ID is passed as the argument, right?
Considering the code,
I feel that if the current task has its environment, i.e the first
condition rtems_current_user_env->task_id==current_task_id is
satisfied, the sharing of the variable from the other task does not
happen, since the other task's variable is got only in the else{...}
part.
The section under the if(){...} only takes care to delete the already
existing private environment for the calling task.
Have I got something wrong here or is there an issue with the routine?
Any help is appreciated. Thank you.
/Bharath
