telnetd server application
Till Straumann
strauman at slac.stanford.edu
Sat Jul 24 07:08:27 UTC 2010
Most likely a configuration issue. Did you see the line
'registering the PTY driver FAILED'? That probably means
you hit the driver limit.
Try
#define CONFIGURE_MAXIMUM_DRIVERS 10
or some other reasonable number.
HTH
- Till
On 07/23/2010 11:23 PM, Yann Sionneau wrote:
> ok ... just forgot the attachement !
> Le 23/07/2010 23:21, Yann Sionneau a écrit :
>> Hi,
>> I am trying to use the telnetd included in RTEMS source tree to start a
>> shell in order to do a nice sample application for the Ethernet driver
>> of milkymist bsp.
>> Is there some documentation about how to use it ?
>> I tried what i thought was correct, according to what i've read in the
>> telnetd source code.
>> I've put the code i am using as attachment.
>> I get this error running the application :
>> *** MILKYMIST NETWORKING TEST by Yann Sionneau ***
>> == Initializing Network ==
>> == Starting telnetd ==
>> WARNING: registering the PTY driver FAILED
>> telnetd cannot initialize PTY driver
>> If you have some advice i would really appreciate :)
>> Cheers,
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100724/ed727c18/attachment.html>
