[Milkymist-devel] telnetd server application
Yann Sionneau yann at minet.net
Sun Jul 25 16:42:00 UTC 2010
Le 25/07/2010 18:39, Joel Sherrill a écrit :
> On 07/25/2010 11:09 AM, Yann Sionneau wrote:
>> Hi again !
>> The ethernet driver was totally wrong, i corrected it now it seems ok
>> I have another problem with telnetd now :
>> syslog: telnetd: accepted connection from 192.168.101.254 on /dev/pty0
>> unable to open stdio: I/O error
> My guess is that you do not have enough file descriptors or
> PTYs configured.  CONFIGURE_MAXIMUM_LIBIO_FILE_DESCRIPTORS
> (from memory) -- 3 for stdin, out, and error plus a few others for
> the socket, telnet (3 per session?), and any file operations you
> will do from the shell.
I just copied the telnetd application from the network-demos.
it has 8 ptys and and 20 file descriptors
> --joel
>> syslog: telnetd: releasing connection from 192.168.101.254 on /dev/pty0
>> do you know how to correct this ?
>> Sorry for flooding the list with my problems :)
>> Le 25/07/2010 12:42, Yann Sionneau a écrit :
>>> Thanks Joel&  Till it helped a lot, telnetd starts well, the problem
>>> comes from my ethernet driver now :)
>>> Le 24/07/2010 15:54, Joel Sherrill a écrit :
>>>> On 07/24/2010 02:08 AM, Till Straumann wrote:
>>>>> Most likely a configuration issue. Did you see the line
>>>>> 'registering the PTY driver FAILED'? That probably means
>>>>> you hit the driver limit.
>>>>> Try
>>>>> #define CONFIGURE_MAXIMUM_DRIVERS 10
>>>>> or some other reasonable number.
>>>> How about CONFIGURE_MAXIMUM_PTYS?
>>>> Yann.. did you look at the network-demos/telnetd?   network-demos
>>>> is a separate CVS module.
>>>> --joel
>>>>> HTH
>>>>> - Till
>>>>> On 07/23/2010 11:23 PM, Yann Sionneau wrote:
>>>>>> ok ... just forgot the attachement !
>>>>>> Le 23/07/2010 23:21, Yann Sionneau a écrit :
>>>>>>> Hi,
>>>>>>> I am trying to use the telnetd included in RTEMS source tree to
>>>>>>> start a
>>>>>>> shell in order to do a nice sample application for the Ethernet
>>>>>>> driver
>>>>>>> of milkymist bsp.
>>>>>>> Is there some documentation about how to use it ?
>>>>>>> I tried what i thought was correct, according to what i've read
>>>>>>> in the
>>>>>>> telnetd source code.
>>>>>>> I've put the code i am using as attachment.
>>>>>>> I get this error running the application :
>>>>>>> *** MILKYMIST NETWORKING TEST by Yann Sionneau ***
>>>>>>> == Initializing Network ==
>>>>>>> == Starting telnetd ==
>>>>>>> WARNING: registering the PTY driver FAILED
>>>>>>> telnetd cannot initialize PTY driver
>>>>>>> If you have some advice i would really appreciate :)
>>>>>>> Cheers,
>>> http://lists.milkymist.org/listinfo.cgi/devel-milkymist.org
>>> IRC: #milkymist at Freenode
>>> Webchat: www.milkymist.org/irc.html
>>> Wiki: www.milkymist.org/wiki
