[Milkymist-devel] telnetd server application
Yann Sionneau yann at minet.net
Fri Jul 30 15:23:40 UTC 2010
Hi again,
what do you mean by "do you have IMFG configured ?"
I used the telnetd application from the network-demos module from CVS.
I just filled-in the informations about network in
network-demos/networkconfig.h and then did :
RTEMS_MAKEFILE_PATH=/opt/rtems-4.11/lm32-rtems4.11/milkymist make
which built all the network-demos applications
Then i uploaded the telnetd application to the Milkymist One board after
connecting it to my laptop via RJ45 ethernet wire and having set the
network as configured inside the network-demos/networkconfig.h file
Here is the *entire* output i get when i try to connect to the board via
telnet 192.168.101.100 :
console_initialize
*** Telnetd Server Test ***
============== Initializing Network ==============
[minimac] Ethernet driver attached
============== Add Route ==============
Destination     Gateway/Mask/Hw    Flags     Refs     Use Expire Interface
default         192.168.101.254    UGS         0        0      0 minimac0
192.168.101.0   255.255.255.0      U           0        0      1 minimac0
192.168.101.254                    UHL         1        0      1 minimac0
============== Start Telnetd ==============
Starting rtemsShell via telnetd -- default account is rtems w/no password
Device: /dev/pty0../dev/pty7 (8)pseudo-terminals registered.
telnetd started with stacksize = 81920 and priority = 100
============== Deleting Init Task ==============
syslog: telnetd: accepted connection from 192.168.101.254 on /dev/pty0
unable to open stdio: I/O error
syslog: telnetd: releasing connection from 192.168.101.254 on /dev/pty0
That's all, and the telnet client stays connected, the tcp connection is
not closed.
In the telnet i get nothing, even if i type something.
And i can connect again after that, and i get the same error (but it's
on /dev/pty1 if i remember correctly, but not sure)
any hints :) ?
Yann.
Le 27/07/2010 10:28, Till Straumann a écrit :
> Do you have IMFS configured? Looks like the underlying
> open("/dev/pty0") call failed with EIO.
> BTW - my usual rant: When submitting a problem report
> you could make our life a *lot* easier if you would attach
> a ****!!!!COMPLETE!!!!**** console log rather than
> editing it and submitting only the few lines that you think
> are important. Even the messages that were printed
> long before the error occurred might give us clues.
> If we don't have this information we might have to go
> back and write messages like this one which takes useless
> time...
> -- T.
> On 07/25/2010 09:43 PM, Yann Sionneau wrote:
>> Le 25/07/2010 21:21, Joel Sherrill a écrit :
>>> On 07/25/2010 11:42 AM, Yann Sionneau wrote:
>>>> Le 25/07/2010 18:39, Joel Sherrill a écrit :
>>>>> On 07/25/2010 11:09 AM, Yann Sionneau wrote:
>>>>>> Hi again !
>>>>>> The ethernet driver was totally wrong, i corrected it now it
>>>>>> seems ok
>>>>>> I have another problem with telnetd now :
>>>>>> /dev/pty0
>>>>> My guess is that you do not have enough file descriptors or
>>>>> PTYs configured.  CONFIGURE_MAXIMUM_LIBIO_FILE_DESCRIPTORS
>>>>> (from memory) -- 3 for stdin, out, and error plus a few others for
>>>>> the socket, telnet (3 per session?), and any file operations you
>>>>> will do from the shell.
>>>> I just copied the telnetd application from the network-demos.
>>>> it has 8 ptys and and 20 file descriptors
>>> Hmm..time for gdb?  Are you on a simulator or real hardware?
>>> If on a simulator, is is possible that the message is coming
>>> from the simulator?
>> I am on real hardware, the message comes from telnetd itself
>> file cpukit/telnetd/telnetd.c , line 388
>>>>> --joel
>>>>>> /dev/pty0
>>>>>> do you know how to correct this ?
>>>>>> Sorry for flooding the list with my problems :)
>>>>>> Le 25/07/2010 12:42, Yann Sionneau a écrit :
>>>>>>> Thanks Joel&    Till it helped a lot, telnetd starts well, the
>>>>>>> problem
>>>>>>> comes from my ethernet driver now :)
>>>>>>> Le 24/07/2010 15:54, Joel Sherrill a écrit :
>>>>>>>> On 07/24/2010 02:08 AM, Till Straumann wrote:
>>>>>>>>> Most likely a configuration issue. Did you see the line
>>>>>>>>> 'registering the PTY driver FAILED'? That probably means
>>>>>>>>> you hit the driver limit.
>>>>>>>>> Try
>>>>>>>>> #define CONFIGURE_MAXIMUM_DRIVERS 10
>>>>>>>>> or some other reasonable number.
>>>>>>>> How about CONFIGURE_MAXIMUM_PTYS?
>>>>>>>> Yann.. did you look at the network-demos/telnetd?   network-demos
>>>>>>>> is a separate CVS module.
>>>>>>>> --joel
>>>>>>>>> HTH
>>>>>>>>> - Till
>>>>>>>>> On 07/23/2010 11:23 PM, Yann Sionneau wrote:
>>>>>>>>>> ok ... just forgot the attachement !
>>>>>>>>>> Le 23/07/2010 23:21, Yann Sionneau a écrit :
>>>>>>>>>>> Hi,
>>>>>>>>>>> I am trying to use the telnetd included in RTEMS source tree to
>>>>>>>>>>> start a
>>>>>>>>>>> shell in order to do a nice sample application for the Ethernet
>>>>>>>>>>> driver
>>>>>>>>>>> of milkymist bsp.
>>>>>>>>>>> Is there some documentation about how to use it ?
>>>>>>>>>>> I tried what i thought was correct, according to what i've read
>>>>>>>>>>> in the
>>>>>>>>>>> telnetd source code.
>>>>>>>>>>> I've put the code i am using as attachment.
>>>>>>>>>>> I get this error running the application :
>>>>>>>>>>> *** MILKYMIST NETWORKING TEST by Yann Sionneau ***
>>>>>>>>>>> == Starting telnetd ==
>>>>>>>>>>> WARNING: registering the PTY driver FAILED
>>>>>>>>>>> telnetd cannot initialize PTY driver
>>>>>>>>>>> If you have some advice i would really appreciate :)
>>>>>>>>>>> Cheers,
