Access my local files using RTEMS
Vinu Rajashekhar vinutheraj at gmail.com
Sat Jul 10 23:36:09 UTC 2010
On Sun, Jul 11, 2010 at 5:02 AM, Vinu Rajashekhar <vinutheraj at gmail.com>wrote:
> On Sun, Jul 11, 2010 at 4:01 AM, Vinu Rajashekhar <vinutheraj at gmail.com>wrote:
>> I was wondering whether there is some way through
>> which I could access my local files using RTEMS,
>> running on qemu ?
>> I tried running the fileio test in samples using the pc386
>> test script, but my local files do not seem to be affected.
>> I changed the config from IMFS to RFS, by the way,
>> before running the test.
> Yes, I am able to access my local files using the technique
> in fileio + pc386 script.
> If you want to modify your local files you have to change the
> fat: option in pc386 to fat:rw:
Additionally, I had to add a config option
CONFIGURE_FILESYSTEM_DOSFS too to make this work.
If anybody knows of any easier way to do this, please
do reply.
URL: <http://lists.rtems.org/pipermail/users/attachments/20100711/1f6c2097/attachment-0001.html>
