Access my local files using RTEMS
Thu Jul 15 06:55:57 UTC 2010
On 12/07/10 1:48 AM, Vinu Rajashekhar wrote:
> I have a follow-up question based on this.
> I could access my local files using pc386
> script and qemu -hda fat: option.
> Similarly, does all the other targets also support
> something like this, if the simulator is not qemu ?
Sorry to butt in on your thread :) :)
Yes qemu provides access via the FAT emulation method. This method has a
limited number of files that can be seen. I am not sure what the limit
is but a large tree of files results in files not appearing with no
errors or warnings.
On real hardware with working networking configurations I use the NFS
file system.
> On Sun, Jul 11, 2010 at 5:06 AM, Vinu Rajashekhar <vinutheraj at gmail.com
> <mailto:vinutheraj at gmail.com>> wrote:
>     On Sun, Jul 11, 2010 at 5:02 AM, Vinu Rajashekhar
>     <vinutheraj at gmail.com <mailto:vinutheraj at gmail.com>> wrote:
>         On Sun, Jul 11, 2010 at 4:01 AM, Vinu Rajashekhar
>             I was wondering whether there is some way through
>             which I could access my local files using RTEMS,
>             running on qemu ?
>             I tried running the fileio test in samples using the pc386
>             test script, but my local files do not seem to be affected.
>             I changed the config from IMFS to RFS, by the way,
>             before running the test.
>         Yes, I am able to access my local files using the technique
>         in fileio + pc386 script.
>         If you want to modify your local files you have to change the
>         fat: option in pc386 to fat:rw:
>     Additionally, I had to add a config option
>     CONFIGURE_FILESYSTEM_DOSFS too to make this work.
>     If anybody knows of any easier way to do this, please
>     do reply.
> rtems-users mailing list
> rtems-users at rtems.org
