rtems 4.10.99.0 issue
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Jul 28 16:42:47 UTC 2010
On 07/28/2010 11:26 AM, Lisa A. Day wrote:
> > env | grep RTEMS
> > will show all the environment variables related to RTEMS that are set.
> > There may be conflicts.
> I have no global env vars set other than the addition of RTEMS to my PATH -
> all env vars are exported during the make process. (I haven't found any env
> vars I'm suppose to be setting documented anywhere.) Even so, env vars
> wouldn't -/couldn't/ - correct the problem of the .cfg file locations
> being inconsistent - some being in /opt/4.10 and some being in /opt/4.11.
> The make process includes most(all?) .cfg files with a path of RTEMS_ROOT.
> BTW: my cvs checkout was this " cvs -d :pserver:... co -P rtems ")
If you are doing that, then you should have /opt/rtems-4.11/bin at the
head of your PATH. 4.10 should not be.
type sparc-rtems4.11-gcc
# should be in /opt/rtems-4.11/bin
type sparc-rtems4.11-gdb
type autoconf
# should also be there
type automake
Then the following should be VERY close to working if
I typed it correctly. Yes .. this is from memory and
just typed in.
cd
mkdir rtems-4.11-work
cd rtems-4.11-work
mkdir bsp-install
cd rtems
./bootstrap
cd ..
mkdir b-sis
cd b-sis
../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis \
--prefix=${HOME}/rtems-4.11-work/bsp-install \
--enable-tests=samples
make
sparc-rtems4.11-run `find . -name sis.ralf`
make install
cd ..
cvs -d :pserver:... co -P examples-v2
cd examples-v2
RTEMS_MAKEFILE_PATH=${HOME}/rtems-4.11-work/bsp-install/sparc-rtems4.11/sis make clean all
At this point, you should have completely built the examples-v2 set for sparc/sis
for RTEMS 4.11
--joel
> > On 07/27/2010 12:55 PM, Lisa A. Day wrote:
> >> Okay - I thought something like that was going on. However, when I
> >> try to copy and compile, for example, examples-v2 in my own dev dir,
> >> make is including *.cfg files within RTEMS_ROOT, which is set to
> >> /opt/rtems-4.11. But not all the *.cfg files are located there; some
> >> are located in /opt/rtems-4.10. I don't understand how I am able to
> >> compile the samples in the CVS co directory but not in my own dev dir.
> >> For example, tracing 'make:
> >> rtems-4.11/make/custom/leon3.cfg includes
> >> $(RTEMS_ROOT)/make/custom/default.cfg
> >> but default.cfg is in /opt/rtems-4.10/ and it includes
> >> $(RTEMS_ROOT)/make/main.cfg
> >> where main.cfg is in /opt/rtems-4.11...
> > Sounds like more than RTEMS_MAKEFILE_PATH is set in your environment.
> >> As for the project, I'm finally on it 1/2 time, have a dev board with
> >> a vertex-4 FPGA configured as a leon3, and have downloaded and ran a
> >> few of your sample apps and also a straight C helloworld app. In the
> >> past, I've been focused on embedded app dev for large projects and
> >> haven't been exposed to much of the system level stuff, so this
> >> project is a great opportunity and I'm learning soooo much - so
> >> cool!! thanks for asking :O)
> > It is fun to get to do low level things. :)
> > --joel
> >> Joel Sherrill wrote:
> >>> On 07/27/2010 11:06 AM, Lisa A. Day wrote:
> >>>> Hate to keep bugging you, but I'm desperate...
> >>>> I found this puzzling: - when I attempted to configure again, I
> >>>> looked closer at these lines of output, particularly the
> >>>> "configure: running".... on line 14 - it sets the prefix to
> >>>> rtems-4.11 -- does this seem
> >>> If this is the CVS head, that makes perfect sense. 4.10 has been
> >>> branched.
> >>> The CVS head will become 4.11 so we follow the naming that it will
> >>> eventually
> >>> take. 4.10.99.0 gives us a number> 4.10 but< 4.11 since this
> >>> isn't the "real"
> >>> 4.11 yet.
> >>> You should be using 4.11 tools with this
> >>> or 4.10 tools with this:
> >>> cvs -d :pserver:... co -r rtems-4-10-branch -P rtems
> >>> How is the project going otherwise? If you need some consulting
> >>> help, that's what I am here for. :)
> >>> --joel
> >>>> > export PATH=/opt/rtems-4.10/bin:$PATH
> >>>> > (I ran ./bootstrap)
> >>>> > ../configure --target=sparc-rtems4.10 --enable-rtemsbsp=leon3
> >>>> --disable-rtems-inline --disable-itron --enable-tests=samples
> >>>> checking for gmake... gmake
> >>>> checking for RTEMS Version... 4.10.99.0
> >>>> checking build system type... i686-pc-linux-gnu
> >>>> checking host system type... i686-pc-linux-gnu
> >>>> checking target system type... sparc-unknown-rtems4.10
> >>>> checking for a BSD-compatible install... /usr/bin/install -c
> >>>> checking whether build environment is sane... yes
> >>>> checking for a thread-safe mkdir -p... /bin/mkdir -p
> >>>> checking for gawk... gawk
> >>>> checking whether gmake sets $(MAKE)... yes
> >>>> checking whether to enable maintainer-specific portions of
> >>>> Makefiles... no
> >>>> configure: creating ./config.status
> >>>> configure: configuring in ./tools/build
> >>>> configure: running /bin/sh '../../../tools/build/configure'
> >>>> '--prefix=/opt/rtems-4.11' '--host=i686-pc-linux-gnu'
> >>>> '--build=i686-pc-linux-gnu' '--enable-rtemsbsp=leon3'
> >>>> '--disable-rtems-inline' '--disable-itron'
> >>>> '--enable-tests=samples' '--target=sparc-rtems4.10'
> >>>> '--cache-file=/dev/null' '--srcdir=../../../tools/build'
> >>>> Daron Chabot wrote:
> >>>>> Something sure doesn't sound right!
> >>>>> Is there a chance that you've set the --prefix=/opt/rtems-4.xx
> >>>>> incorrectly when configuring, and some files are installed in the
> >>>>> wrong place ?
> >>>>> You should never need to touch RTEMS_ROOT; setting
> >>>>> RTEMS_MAKEFILE_PATH to /opt/rtems-4.11/sparc-rtems/someBSP is all
> >>>>> you need.
> >>>>> Since you've built both 4.10 and 4.11, you can switch between
> >>>>> building apps for either of the two by appropriately setting
> >>>>> RTEMS_MAKEFILE_PATH...
> >>>>> HTH.
> >>>>> On Mon, Jul 26, 2010 at 5:15 PM, Lisa A. Day<day at lanl.gov
> >>>>> <mailto:day at lanl.gov>> wrote:
> >>>>> I found at least part of the problem compiling example-v2/hello.
> >>>>> My cvs checkout of rtems 4.10 built both /opt/rtems-4.10 and
> >>>>> /opt/rtems-4.11directories. FYI, I did a fresh check sometime
> >>>>> soon after 4.10 was released and 4.11 became the CVS Mainline; I
> >>>>> also checked the CVS build status when I checked it out, and the
> >>>>> SPARC was building successfully.
> >>>>> However, 'make' in examples-v2/hello is looking for *.cfg files
> >>>>> in RTEMS_ROOT, which, based on the make/README file I should set
> >>>>> to /opt/rtems-4.11. But some of the necessary .cfg files are
> >>>>> located there while others are located in /opt/rtems-4.10. For
> >>>>> example, $(RTEMS_ROOT)/make/custom/default.cfg can be found when
> >>>>> RTEMS_ROOT is set to /opt/rtems-4.10/ --- but default.cfg
> >>>>> includes main.cfg which in /opt/rtems-4.11...
> >>>>> Am I describing this clearly? Do I need to do yet another cvs
> >>>>> checkout (I attempted a few before I finally got it all right)
> >>>>>> Setting RTEMS_ROOT should not be necessary.
> >>>>>> On Mon, Jul 26, 2010 at 11:12 AM, Gedare Bloom
> >>>>>> <gedare at gwmail.gwu.edu <mailto:gedare at gwmail.gwu.edu>> wrote:
> >>>>>> Are you talking about building standalone apps? If so, you
> >>>>>> might try
> >>>>>> looking at the examples-v2 CVS repository, which has some
> >>>>>> sample
> >>>>>> applications that build outside of RTEMS. You still have to
> >>>>>> point the
> >>>>>> Makefile to the installed/built rtems, by setting the
> >>>>>> RTEMS_MAKEFILE_PATH and RTEMS_ROOT environment variables.
> >>>>>> If you build and install RTEMS to
> >>>>>> /opt/rtems-4.10/sparc-rtems4.10 then
> >>>>>> I think you want:
> >>>>>> RTEMS_MAKEFILE_PATH=/opt/rtems-4.10/sparc-rtems4.10/leon3
> >>>>>> RTEMS_ROOT=/opt/rtems-4.10
> >>>>>> If you are talking about building the sptests/psxtests etc,
> >>>>>> then check
> >>>>>> how you configure RTEMS, if you have --enable-tests=samples,
> >>>>>> then
> >>>>>> configure won't setup the build for the other test
> >>>>>> executables.
> >>>>>> Instead you just want --enable-tests, which I believe is the
> >>>>>> default
> >>>>>> option.
> >>>>>> -Gedare
> >>>>>> On Mon, Jul 26, 2010 at 10:57 AM, Lisa A. Day<day at lanl.gov
> >>>>>> > I'm learning RTEMS (4.10) and have successfully been able
> >>>>>> to build, load,
> >>>>>> > and run the testsuites/samples programs on my leon3 dev
> >>>>>> board without
> >>>>>> > problem. However, outside this samples directory, I have
> >>>>>> not been able to
> >>>>>> > build any of the apps. I don't know if its a Makefile
> >>>>>> issue or not... My
> >>>>>> > thought is if I could get my hands on one of the
> >>>>>> testsuites/samples
> >>>>>> > makefiles that is not dependent on the installation dir, I
> >>>>>> can make sense of
> >>>>>> > where I'm going astray -- CONFIG, environment, or path
> >>>>>> issues, etc.
> >>>>>> > Does anyone have such an example?
> >>>>>> > Lisa A. Day
> >>>>>> > ISR-3: Space Data Systems
> >>>>>> > MS D440
> >>>>>> > Los Alamos, NM 87545
> >>>>>> > (505) 665-4780
> >>>>>> > _______________________________________________
> >>>>>> > rtems-users mailing list
> >>>>>> > rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> >>>>>> > http://www.rtems.org/mailman/listinfo/rtems-users
> >>>>> Lisa A. Day
> >>>>> MS D440
> >>>>> (505) 665-4780
> >>>> Lisa A. Day
> >>>> MS D440
> >>>> (505) 665-4780
> >> Lisa A. Day
> >> MS D440
> >> (505) 665-4780
> Lisa A. Day
> MS D440
> (505) 665-4780
> Lisa A. Day
> MS D440
> (505) 665-4780
Joel Sherrill, Ph.D. Director of Research& Development
