5KHz acquisition control
Robert Deschambault
robert.deschambault at gmail.com
Mon Jun 7 20:23:53 UTC 2010
Hi,
In my opinion, I wouldn't run the RTEMS with a clock tick like that, I would
find a way to generate an external interrupt based on a hardware timer. I
have successfully run RTEMS on a 40 MHz LEON2, with no changes to the RTEMS
clock ticks, to accept a 16 KHz interrupt signal for a fuzzy logic control
loop to control a gimbal. Worked very well.
On Mon, Jun 7, 2010 at 4:12 PM, Matt Rippa <mrippa at gemini.edu> wrote:
> Hi -
> I would like to know your thoughts regarding common practices for an RTEMS
> system requiring a 5 KHz sample rate. The hardware is 600MHz i386/PC-104
> based. Reading through the RTEMS C users guide the Rate Monotonic Scheduler
> appears to be what I'm interested in. Basically I need to read inputs from
> hardware, filter and process results, then write outputs with a period of
> 200 us.
> I understand I can set the RTEMS system clock ticks to get this resolution.
> My question is, is this a common and recommend practice for this kind of
> sample rate? Or do people favor using on-board programmable interrupt timers
> for this purpose? Is using an external interrupt timer on the pci bus a
> common practice if your SBC doesn't provide any timers?
> Thanks for any input.
> -Matt Rippa
> rtems-users mailing list
> rtems-users at rtems.org
Bob Deschambault
6614 Astro Court, Mississauga
Ontario, Canada L5N 7J2
home: 905 824 7159
cell: 416 457 7163
URL: <http://lists.rtems.org/pipermail/users/attachments/20100607/81a27b80/attachment.html>
