[fredette at csail.mit.edu: sun2/sun3/sun4c/sun4u emulator]
Gedare Bloom gedare at gwmail.gwu.edu
Tue Jun 8 14:13:09 UTC 2010
Thanks for the pointer. AFAIW the sun2 and sun3 targets aren't
SPARC-based.  However, SPARCstation is SPARC V7 (so not too different
from the sparc RTEMS), and the sun-4u is SPARC V9, for which I'll be
releasing an RTEMS port in 4.11 -- So I will check this out and see if
it might be useful as a testing tool.
-Gedare
On Mon, Jun 7, 2010 at 8:58 PM, Aaron J. Grier <agrier at poofygoof.com> wrote:
> passing this on; I don't know if anybody is interested in targeting sun
> hardware specifically, but it may be of interest for sparc targets in
> general.
>  Aaron J. Grier | "Not your ordinary poofy goof." | agrier at poofygoof.com
> ---------- Forwarded message ----------
> From: fredette at csail.mit.edu
> To: port-sun2 at netbsd.org, port-sun3 at netbsd.org, port-sparc at netbsd.org, port-sparc64 at netbsd.org
> Date: Sun, 06 Jun 2010 21:04:32 -0400
> Subject: sun2/sun3/sun4c/sun4u emulator
> Hi.  The new version of tme, 0.8, can also emulate an Ultra 1, and
> on x86 hosts with a supported host OS, the SPARCstation 2 and Ultra 1
> emulations will now do dynamic binary translation.  NetBSD 5.x seems
> to run pretty well on the different emulations.
> However, please remember that tme comes with no warranty.  Don't
> trust it to do anything correctly.
>  In particular, do not trust tme for floating-point work.  The
>  m68881 and sparc FPU emulations may not be exact.
> tme is meant to be very portable.  It should work on most Unix-like
> systems, including on 64-bit CPUs.  Instructions on how to download,
> build, and use it (including some screenshots) are at:
> http://csail.mit.edu/~fredette/tme/index.html
> Many thanks to Izumi Tsutsui, for testing and the pkgsrc entry.
> The code is still rough and the distribution isn't too user-friendly, but
> if you follow the instructions carefully, and have experience installing
> NetBSD on Sun machines, you just might end up with some emulated Suns.
> Matt Fredette
> rtems-users mailing list
> rtems-users at rtems.org
