Antwort: Re: Antwort: Re: configure ACK delay for TCP
Eric Norum
wenorum at lbl.gov
Tue Jun 8 19:59:49 UTC 2010
On Jun 8, 2010, at 11:15 AM, Wolfgang Rostek wrote:
> >> 15 30.098174 192.168.18.47 192.168.18.135 TCP
> >> 50569 > 5477 [PSH, ACK] Seq=2201 Ack=1 Win=5856 Len=800 TSV=23499477 TSER=43
> > Did the receive thread not get awoken by the arrival of the above
> > packet? There's no indication in the frame/clock lines below. Was
> > there a line '15' that you did not include in the messaget?
> I don't have line '15' handling on file but it was identical to '17'
> as described before.
> As far as I understand is the call to rtems_bsdnet_event_receive() a kind
> of announcing an event. The next time clock or other interrupts invoke
> the 'schedular' it dispatches these events to awaiting apps like the TCP
> state machine. Per default this machine has a 200 ms ACK delay and it will
> wait for several clock ticks until ACK is generated and send.
> (I hope I'm not totally wrong here)
I'm afraid that your understanding is a little off.
The rtems_bsdnet_event_receive routine simply blocks waiting for the interrupt handler to send the event that indicates that a packet has arrived. The receive thread then passes the packet up to the rest of the network stack for further processing (and ultimately acknowledgement).
This is why I say that you really do not want to change the arguments to the rtems_bsdnet_event_receive routine since doing so will merely make the receive thread poll for packet arrival instead of blocking and waiting for an interrupt to occur.
> >> rtems_bsdnet_event_receive (INTERRUPT_EVENT | FATAL_INT_EVENT,
> > Right -- and it appears the it returns from this function whenever a
> > packet is received.
> Until now I did analyse network.c and have only a rough idea what's going
> on beyong this call.
> >> I've got the hint from Thomas to use the socket options to force an
> >> immediate ACK.
> > Yes, I would say that the delay is coming from somewhere else other
> > than the receive thread since that thread appears to be responding
> > to the interrupts caused by arriving packets as it should. I think
> > that it would be a very bad idea to turn the receive thread from
> > being interrupt driven as it is now to instead be polling which it
> > would become if your patch were applied.
> Any idea where this default ACK delay value is defined (200 ms)? No
> easy way to figure it out within the TCP/BSD stuff.
> regards
> Wolfgang R.
Eric Norum
wenorum at lbl.gov
URL: <http://lists.rtems.org/pipermail/users/attachments/20100608/71ed7dd1/attachment.html>
