still can't boot mvme2100
Heinz Junkes
junkes at fhi-berlin.mpg.de
Wed Jun 9 10:29:16 UTC 2010
Joel,
i am so sorry ... it was the PReP network boot setting, i haven't activated it on the board ...
i really have checked it more then one ... my fault :-(
Sorry for that, everything works perfect and again thank you for your quick answers and your support,
Heinz
On Jun 9, 2010, at 1:17 AM, Joel Sherrill wrote:
> On 06/08/2010 09:15 AM, Till Straumann wrote:
>> Heinz.
>> I just booted your 'hello.ralf' you sent me off-line on my mvme2100
>> which worked fine (see below). Hence, I suspect something with
>> your setup must be wrong (did you check the PReP network boot
>> setting in ENV?)
> Till.. It has been a long time but I remember that the settings
> in PPCBug had to be just right. Does the info here match your
> board?
> http://www.rtems.org/wiki/index.php/Mvme2100
> --joel
>> HTH
>> -- Till
>> PPC5-Bug>nbo
>> Network Booting from: DEC21143, Controller 0, Device 0
>> Device Name: /pci at fec00000/pci1011,19 at e,0:0,0
>> Loading: Operating System
>> Client IP Address = 134.79.33.137
>> Server IP Address = 134.79.33.86
>> Gateway IP Address = 0.0.0.0
>> Subnet IP Address Mask = 255.255.252.0
>> Boot File Name = hello.ralf
>> Argument File Name =
>> Network Boot File load in progress... To abort hit <BREAK>
>> Bytes Received =&175944, Bytes Loaded =&175944
>> Bytes/Second =&175944, Elapsed Time =1 Second(s)
>> Residual-Data Located at: $01F5511C
>> Model: 0 (e2)
>> Serial: MOT06B6D26
>> Processor/Bus frequencies (Hz): 199998720/66666240
>> Time Base Divisor: 4000
>> Memory Size: 2000000
>> PCI: Probing PCI hardware
>> RTEMS 4.x/PPC load:
>> Uncompressing the kernel...
>> done
>> Now booting...
>> Welcome to rtems-4.9.99.0(PowerPC/Generic (classic FPU)/mvme2100) on MVME 2100
>> pci : Configuring interrupt routing for 'MVME 2100'
>> pci : Device 0:0x00:0 routed to interrupt_line 16
>> pci : Device 0:0x0D:0 routed to interrupt_line 23
>> pci : Device 0:0x0E:0 routed to interrupt_line 17
>> Cleared PCI errors: pci_stat was 0x20A0
>> WARNING: unable to allocate page table, keeping DBAT0
>> WARNING: unable to setup page tables VME bridge must share PCI space
>> OpenPIC Version 1.2 (1 CPUs and 24 IRQ sources) at 0xFCE40000
>> OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 1
>> Overriding NumSources (24) from configuration with 16
>> OpenPIC timer frequency is 8333216 Hz
>> Universe II PCI-VME bridge detected at 0xFCDFF000, IRQ 23
>> Universe Master Ports:
>> Port VME-Addr Size PCI-Adrs Mode:
>> 0: 0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
>> 1: 0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
>> 2: 0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
>> Universe Slave Ports:
>> 0: 0xC0000000 0x02000000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN, PREN
>> Registering /dev/console as minor 0 (==/dev/ttyS0)
>> *** HELLO WORLD TEST ***
>> Hello World
>> *** END OF HELLO WORLD TEST ***
>> On 06/08/2010 07:49 AM, Heinz Junkes wrote:
>>> Hi,
>>> i have now made a fresh installtion of rtems-tools 4.10 from source for powerpc on debian lenny 5.0.4.
>>> From the cvs i have loaded the rtems-4.9.4.
>>> I could the hello_world test file. But still run into "Illegal Instruction" when i start hello.ralf
>>> as i mentioned in my last mail:
>>> Network Boot File load in progress... To abort hit<BREAK>
>>> Bytes Received =&2524435, Bytes Loaded =&2524435
>>> Bytes/Second =&841478, Elapsed Time =3 Second(s)
>>> Exception: Program (Illegal Instruction)
>>> SRR0 =001F0000 SRR1 =00083040 Vector-Offset =00700
>>> The cpu board i use have 64 Mbyte of memory installed. Have i to modify mvme2100.cfg, linkcmds ?
>>> Will the mvme3100 - board run with RTEMS? I would buy such kind of boards if i can not get the mvme2100
>>> to run in the next two month ...
>>> Regards,
>>> Heinz
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20100609/9c2d7c42/attachment.bin>
