Error With Networking when Upgrading
jcristy at motioncontrol.org
Fri Jun 11 14:25:43 UTC 2010
Chris,
Thanks for the reply. I have tried different stack sizes for the Rx thread (4096 to 512 *
4096), but it seems to top out at around 9 clusters. I can call
rtems_bsdnet_show_mbuf_stats(); here is what i get:
in bsd_init() after the mbuf data structures are set up
************ MBUF STATISTICS ************
mbufs:4096 clusters:1024 free:1024
drops: 0 waits: 0 drains: 0
free:4096 data:0 header:0 socket:0
pcb:0 rtable:0 htable:0 atable:0
soname:0 soopts:0 ftable:0 rights:0
ifaddr:0 control:0 oobdata:0
at the beginning of fec_RxDaemon()
free:4095 data:1 header:0 socket:0
in mclalloc()
mbufs:4096 clusters:1024 free:1018
drops: 0 waits: 0 drains: 1
free:4088 data:8 header:0 socket:0
Also, I noticed that the mclfree->mcl_next list is intact until I call rtems_bsdnet_newproc to
start rxDaemon. More specifically, it is ruined at the call of rtems_task_create inside
rtems_bsdnet_newroc. When it breaks, the list begins to include 0's at the same point, as
expected, that rxDaemon is unable to continue.
Thanks again,
John
On 11 Jun 2010 at 8:42, Chris Johns wrote:
Date sent: Fri, 11 Jun 2010 08:42:17 +1000
To: jcristy at motioncontrol.org
Copies to: rtems-users at rtems.org
Subject: Re: Error With Networking when Upgrading
> On 11/06/10 3:33 AM, jcristy at motioncontrol.org wrote:
> > I am working on upgrading from 4.7.1 to 4.9.4. I am encountering an error: "Still Waiting for
> > mbuf cluster" in m_clalloc in rtems_glue.c. It seems that in fec_RxDaemon it will allocate 5
> > clusters before coming to the error. I haven't changed anything else. Are there any things
> > that are known to cause this error that I can check for?
> How much memory is allocated to the stack ?
> Are you able to call 'rtems_bsdnet_show_mbuf_stats()' ?
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20100611/1daf5c27/attachment.html>
