Possible bug in cpukit/score/src/objectgetbyindex.c
Tue Jun 15 12:42:49 UTC 2010
On 06/15/2010 06:44 AM, Wendell Pereira da Silva wrote:
> Hi,
> Is this code correct? I think a call to _Thread_Enable_dispatch() is
> missing (as indicated below).
I am happy to say yes it is.  All _Objects_Get variation
return with thread dispatching disabled if the object
is local and exists.  The converts the id to a pointer
and puts you in a critical section as an atomic
operation.  It is the responsibility of the caller to
enable dispatch before returning.
See something like tasksetnote.c for a simple
example of the pattern.
> Objects_Control *_Objects_Get_by_index(
>   Objects_Information *information,
>   uint32_t             index,
>   Objects_Locations   *location
>   Objects_Control *the_object;
> if ( information->maximum >= index ) {
> *_Thread_Disable_dispatch(); *
>     the_object = information->local_table[ index ];
> if ( the_object ) {
>       *location = OBJECTS_LOCAL;
> *      [***** Is a call to _Thread_Enable_dispatch() missing here? ****]*
> return( the_object );
> *_Thread_Enable_dispatch();*
>     *location = OBJECTS_ERROR;
> return( NULL );
> Regards,
> Wendell.
