rtems with matlab autocode problems
João Rasta
freakforever at gmail.com
Wed Jun 16 15:52:19 UTC 2010
Hi,
No, autocode requires the real-time workbench only, it is quite
straightforward to generate the code.
I didn't fully understood your question. Anyway, i have tried to compile the
application with gcc and runs fine on linux so it should run on rtems with
the apropriate modifications. However, when i printf("test\n") within the
library finction, it returns strange characters, which doesn't happen in the
function that calls the library function..
I suspect of a compilation flag/option i may be missing on the library. Do
you have any idea?
Also, i don't need any rtems primitives/configurations on the library
functions right? I'm assuimng It is enough to have the rtems configuration
on the "main" file.
Best,
JM
On Wed, Jun 16, 2010 at 4:42 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
> On 06/16/2010 10:38 AM, João Rasta wrote:
>> Hi,
>> I'm having trouble running an rtems application that uses code generated
>> from matlab using autocode. It all goes well until a function of this
>> library is called: printfs return awkward characters and then the
>> application crashes.
>> I have seen references to this before. Is this hard to do? Are there
> instructions?
> Standard glue code, etc.
> 1) Is there any obvious reason to why printfs of the autocode generated
>> functions are not working properly? They are compiled with sparc-rtems-gcc,
>> as the main code.
>> 2) Are there any special flags needed to be passed to the compiler in
>> order to link other libraries? Or some rtems configuration..
>> Is there any chance it is printing floating point numbers from a non-FP
> task?
>> Best,
>> JM
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20100616/4c5d181c/attachment.html>
