rtems with matlab autocode problems
Till Straumann
strauman at slac.stanford.edu
Wed Jun 16 17:31:45 UTC 2010
Can you post the offending code?
T.
On 06/16/2010 12:02 PM, João Rasta wrote:
> Just an update:
> If i do fflush(stdout) inside the test function, the application
> crashes. Also, no matter what i put in printf, it allways prints the
> same characters, but it detects the \n correctly.. I don't see if this
> can be related to the compiler..
> Best,
> JM
> On Wed, Jun 16, 2010 at 4:56 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
> On 06/16/2010 10:52 AM, João Rasta wrote:
> Hi,
> No, autocode requires the real-time workbench only, it is
> quite straightforward to generate the code.
> I didn't fully understood your question. Anyway, i have tried
> to compile the application with gcc and runs fine on linux so
> it should run on rtems with the apropriate modifications.
> However, when i printf("test\n") within the library finction,
> it returns strange characters, which doesn't happen in the
> function that calls the library function..
> Is it including stdio.h? I have seen some targets where if you
> don't the variable
> arguments stuff gets confused.
> Is the generated code warning free?
> I suspect of a compilation flag/option i may be missing on the
> library. Do you have any idea?
> As long as it is compiled the same as the rest of the app, it
> should be ok.
> Also, i don't need any rtems primitives/configurations on the
> library functions right? I'm assuimng It is enough to have the
> rtems configuration on the "main" file.
> Right.
> Can you print from other tasks?
> --joel
> Best,
> JM
> On Wed, Jun 16, 2010 at 4:42 PM, Joel Sherrill
> <mailto:joel.sherrill at oarcorp.com>>> wrote:
> On 06/16/2010 10:38 AM, João Rasta wrote:
> Hi,
> I'm having trouble running an rtems application that
> uses code
> generated from matlab using autocode. It all goes well
> until a
> function of this library is called: printfs return awkward
> characters and then the application crashes.
> I have seen references to this before. Is this hard to do?
> Are
> there instructions?
> Standard glue code, etc.
> 1) Is there any obvious reason to why printfs of the
> autocode
> generated functions are not working properly? They are
> compiled with sparc-rtems-gcc, as the main code.
> 2) Are there any special flags needed to be passed to the
> compiler in order to link other libraries? Or some rtems
> configuration..
> Is there any chance it is printing floating point numbers
> from a
> non-FP task?
> Best,
> JM
> -- Joel Sherrill, Ph.D. Director of
> Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> Joel Sherrill, Ph.D. Director of Research& Development
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100616/31a26e91/attachment.html>
