rtems with matlab autocode problems
João Rasta
freakforever at gmail.com
Thu Jun 17 09:33:11 UTC 2010
Well, i'm using regular printf. I would not point to the encoding since it
allways prints the same thing no matter what i pass to printf().
I removed the 3 optimization in the gcc flags and removed the other ones and
the same problem occurs. If i remove the printf the application exits on the
following instruction
IU in error mode (tt = 0x2b)
4000ca8c d127bfec st %f8, [%fp - 0x14]
. I'm initializing rtems with:
#define CONFIGURE_INIT
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE (300*1024)
#define CONFIGURE_MAXIMUM_POSIX_THREADS 10
#define CONFIGURE_MAXIMUM_POSIX_MUTEXES 10
#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 5
#define CONFIGURE_POSIX_INIT_THREAD_TABLE
I think i have enough stack space.
Also, if i point CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT to a function
declared on the autocode the printfs do not work well, which does not happen
if i point it to a function declared on the main code.
The autocode is compiled with sparc-rtems-gcc and a library libgnc.a is
created which is then passed to the compiler at link time with -lgnc. The
library is created with
ar ruvs libgnc.a *.o
Does it make sense that there may be a problem with the compiled .o's of the
library? If so, how can its declared functions be messing up with memory
operations and not on the main code? They use the same compiler..
Best,
JM
On Thu, Jun 17, 2010 at 4:18 AM, Ralf Corsepius <ralf.corsepius at rtems.org>wrote:
> On 06/16/2010 07:48 PM, João Rasta wrote:
>> Yes, here goes
>> // dummy printf test code
>> int upa(void)
>> int i = 0;
>> for (i=0; i< 20; i++)
>> printf("B\n");
>> exit(0);
>> And the result is:
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> ¬ÖUf
>> Program exited normally.
> Hmm, I am seeing "4 characters per line" instead of "1 or 2 characters per
> line" as one would expect.
> Are you sure your code uses the right printf? 4 chars instead of 1 could
> indicate using UTF8 or UTF16 encoding instead of ACSII.
> sparc-rtems-gcc -c -O3 -g3 -ffloat-store -fPIC -DUSE_RTMODEL -DMODEL=gnc
>> -DRT -DNUMST=1 -DTID01EQ=0 -DNCSTATES=0 -DUNIX -DMT=0 -DHAVESTDI
>> O -I. -I../../rtwlt/matlab/simulink/include
>> -I../../rtwlt/matlab/extern/include -I../../rtwlt/matlab/rtw/c/src
>> src/ext_mode/common -I. -I.. -I../../rtwlt/matlab/rtw/c/libsrc
>> ../../rtwlt/matlab/rtw/c/src/rt_sim.c
> ... -O3 -g3 -ffloat-store -fPIC
> certainly leave room for speculation on incompatibility.
> -03 ... switches on dangerous optimizations
> -ffloat-store ... could be incompatible to rtems-gcc/newlib
> -fPIC ... unneeded, unused by the rtems-toolchains, unknown
> side effects on rtems-gcc/newlib
> Ralf
URL: <http://lists.rtems.org/pipermail/users/attachments/20100617/47f1d63d/attachment.html>
