rtems with matlab autocode problems
Jiri Gaisler jiri at gaisler.com
Thu Jun 17 14:38:29 UTC 2010
Setting -O0 is equal to wasting ~ 70% of the cpu performance.
Just so you know ....
Jiri.
João Rasta wrote:
> Dear all,
> I have finally managed to solve this issue by using the following
> compilation flags *only* on the autocode library:
> OPT_OPTS = -O0 -g -fmessage-length=0
> I suspect of the ffloat-store and O3 optimization flags placed on the
> library makefile by default by matlab, and mabe my answer to Ralf was
> affected by not touch'ing all the project files before compilation.
> I'm extremely grateful for all your valuable help.
> Best,
> JM
> On Thu, Jun 17, 2010 at 12:56 PM, Manuel Coutinho
> <manuel.coutinho at edisoft.pt <mailto:manuel.coutinho at edisoft.pt>> wrote:
>     Hi
>     Are you sure you are using the correct baud rate to comunicate with
>     the board (using GRMON)?
>     Did you try different baud rates?
>     Regards
>     Manuel Coutinho
>     Software Engineer - Space
>     EDISOFT, S.A.
>     Rua Quinta dos Medronheiros - Lazarim
>     Apartado 382 Monte de Caparica
>     2826-801 Caparica Portugal
>     Tel:        (+351) 212 945 900
>     Fax:        (+351) 212 945 999
>         *From:* rtems-users-bounces at rtems.org
>         <mailto:rtems-users-bounces at rtems.org>
>         [mailto:rtems-users-bounces at rtems.org
>         <mailto:rtems-users-bounces at rtems.org>] *On Behalf Of *João Rasta
>         *Sent:* Thursday, June 17, 2010 10:33 AM
>         *To:* Ralf Corsepius
>         *Cc:* rtems-users at rtems.com <mailto:rtems-users at rtems.com>
>         *Subject:* Re: rtems with matlab autocode problems
>         Well, i'm using regular printf. I would not point to the
>         encoding since it allways prints the same thing no matter what i
>         pass to printf().
>         I removed the 3 optimization in the gcc flags and removed the
>         other ones and the same problem occurs. If i remove the printf
>         the application exits on the following instruction
>         IU in error mode (tt = 0x2b)
>          4000ca8c  d127bfec   st  %f8, [%fp - 0x14]
>         . I'm initializing rtems with:
>         #define CONFIGURE_INIT
>         #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>         #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>         #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
>         #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE (300*1024)
>         #define CONFIGURE_MAXIMUM_POSIX_THREADS             10
>         #define CONFIGURE_MAXIMUM_POSIX_MUTEXES                10
>         #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES            5
>         #define CONFIGURE_POSIX_INIT_THREAD_TABLE
>         I think i have enough stack space.
>         Also, if i point CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT  to a
>         function declared on the autocode the printfs do not work well,
>         which does not happen if i point it to a function declared on
>         the main code.
>         The autocode is compiled with sparc-rtems-gcc and a library
>         libgnc.a is created which is then passed to the compiler at link
>         time with -lgnc. The library is created with
>         ar ruvs libgnc.a *.o
>         Does it make sense that there may be a problem with the compiled
>         .o's of the library? If so, how can its declared functions be
>         messing up with memory operations and not on the main code? They
>         use the same compiler..
>         Best,
>         JM
>         On Thu, Jun 17, 2010 at 4:18 AM, Ralf Corsepius
>         <ralf.corsepius at rtems.org <mailto:ralf.corsepius at rtems.org>> wrote:
>             On 06/16/2010 07:48 PM, João Rasta wrote:
>                 Yes, here goes
>                 // dummy printf test code
>                 int upa(void)
>                     int i = 0;
>                     for (i=0; i<  20; i++)
>                         printf("B\n");
>                     exit(0);
>                 And the result is:
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                     ¬ÖUf
>                 Program exited normally.
>             Hmm, I am seeing "4 characters per line" instead of "1 or 2
>             characters per line" as one would expect.
>             Are you sure your code uses the right printf? 4 chars
>             instead of 1 could indicate using UTF8 or UTF16 encoding
>             instead of ACSII.
>                 sparc-rtems-gcc -c -O3 -g3 -ffloat-store -fPIC
>                 -DUSE_RTMODEL -DMODEL=gnc
>                 -DRT -DNUMST=1 -DTID01EQ=0 -DNCSTATES=0 -DUNIX -DMT=0
>                 -DHAVESTDI
>                 O   -I. -I../../rtwlt/matlab/simulink/include
>                 -I../../rtwlt/matlab/extern/include
>                 -I../../rtwlt/matlab/rtw/c/src
>                 src/ext_mode/common -I. -I..
>                 -I../../rtwlt/matlab/rtw/c/libsrc
>                 ../../rtwlt/matlab/rtw/c/src/rt_sim.c
>             ... -O3 -g3 -ffloat-store -fPIC
>             certainly leave room for speculation on incompatibility.
>             -03 ... switches on dangerous optimizations
>             -ffloat-store ... could be incompatible to rtems-gcc/newlib
>             -fPIC ... unneeded, unused by the rtems-toolchains, unknown
>               side effects on rtems-gcc/newlib
>             Ralf
> rtems-users mailing list
> rtems-users at rtems.org
