Ethernet communication
João Rasta
freakforever at gmail.com
Tue Jun 22 14:49:37 UTC 2010
Hello,
I'm somewhat confused about implementing TCP (UDP)/IP communications in
RTEMS. This is because i have seen the RTEMS Network Supplement doc and the
networkconfig.h. However, i'm used to regular sockets. So:
1) Can i use regular TCP or UDP sockets in RTEMS? If so, do i need to
initialize the ethernet driver with RTEMS_BSP_NETWORK_DRIVER_ATTACH? And in
this case, why is the networkconfig.h needed?
2) Is there another way to implement ethernet communications in RTEMS using
pre-defined functions?
Best,
JM
URL: <http://lists.rtems.org/pipermail/users/attachments/20100622/6f680cb7/attachment.html>
