Unexpected trap(0 x4) ... fp disabled
Jiri Gaisler jiri at gaisler.com
Wed Jun 23 20:49:47 UTC 2010
If you have built the project using our eclipse plugin, then it should
be enough to select -msoft-float in the project compiler settings.
Jiri.
Gardner, Michael T wrote:
> Jiri,
> We are using the Gaisler built version of RTEMS 4.10.  Specifically,
> sparc-rtems-4.10-gcc-4.3.3-1.1.99.10-linux.tar.bz2.
> I would like to post the disassembly around address 0x40006710, but my
> inexperience with low level assembly tools doesn’t reach quite far
> enough.  I’ve been able to single step using the eclipse debugger and
> thus become aware of some of the address, but I haven’t found a way yet
> to disassemble the code at the addresses you request.  Do you have a
> suggestion on how to do this?  Thanks!
> Michael T. Gardner
> Sandia National Labs
> mtgardn at sandia.gov
> 505-844-1299
> rtems-users mailing list
> rtems-users at rtems.org
