Failed writes to block devices don't report an error
Arnout Vandecappelle arnout at mind.be
Fri Jun 25 10:07:30 UTC 2010
On Thursday 24 June 2010 01:12:14, Chris Johns wrote:
> >> This would be good to have. I see it being needed which ever way we
> >> go.
> >> I also see the following:
> >>    if (write(fd, buf, size) != size)
> >>      goto handle_error
> >>    if (sync_call(..)<  0)
> >>      goto handle_error
> >> in an application could be a work around until a more standard
> >> approach is made. I prefer this over the other suggestions.
> > ...which is why I put it as the first one :-)
> If you are using the DOSFS it may pay to check if it has hold of a
> buffer that may not be flushed. I think there are paths that can result
> in it holding a buffer. The sync call currently does not touch the file
> systems.
 sync_call() doesn't, but fsync(fd) does.
 However, I'm not sure if dosfs also syncs the FAT in that case.  It really
should.
 Regards,
 Arnout
Arnout Vandecappelle                               arnout at mind be
Senior Embedded Software Architect                 +32-16-286540
Essensium/Mind                                     http://www.mind.be
G.Geenslaan 9, 3001 Leuven, Belgium                BE 872 984 063 RPR Leuven
LinkedIn profile: http://www.linkedin.com/in/arnoutvandecappelle
GPG fingerprint:  31BB CF53 8660 6F88 345D  54CC A836 5879 20D7 CF43
