Thumb-2/ARMv7/Cortex-M support.
Christian Castellaro christian.castellaro at students.hevs.ch
Mon Jun 28 08:14:54 UTC 2010
Thanks a lot for your answer.
I must (if possible) complete the port for friday 9th of july 2010... I'm short I know ;-)
>From what I know cortex architecture is completely different than previous ARM cores. The current ARM port could be a good starting point to understand how to port RTEMS but quite everything will have to be rewritten.
For the moment I can't even compile RTEMS for a supported cpu (powerpc) and bsp (psim) :-(
I'll post this problem in a new entry
If I do some acceptable work I'll share my code and results.
have a nice day thanks
-----Original Message-----
To: Christian Castellaro <christian.castellaro at students.hevs.ch>
Date: Sun, 27 Jun 2010 13:24:46 -0700 (PDT)
Subject: Re: Thumb-2/ARMv7/Cortex-M support.
We could work together on this, but I only have a small amount of time to dedicate to it at the moment.  I have a couple of different Cortex-M3 devel kits I can test on.
I am not quite sure where to start myself.  I was thinking the best place to start was the cpukit arm code in cpukit/score/cpu/arm and see what needs to be changed/modified for cortex-m3.
Thanks,
Mike
----- Original Message ----
> From: Christian Castellaro <christian.castellaro at students.hevs.ch>
> To: mprtems at bellsouth.net
> Cc: rtems-users at rtems.org
> Sent: Wed, June 23, 2010 5:52:09 AM
> Subject: Thumb-2/ARMv7/Cortex-M support.
> Hello Mike,
I need to make a port of RTEMS for a Cortex M3. But I don't
> know how I can do this.
Do you have any advice on what source files to
> modify?
Wouldn't it be more efficient if we joined efforts?
Thank
> you very much
christian castellaro
