RTEMS PowerPC progress.
Nick Thomas
nick.thomas at pixsan.com
Thu Jun 3 15:04:38 UTC 2010
> another idea: the ppc405 knows different kinds of interrupts, including
> "critical interrupts". I am not really sure now which kinds of
> interrupts get blocked, when rtems_interrupt_disable() is called, so an
> idea would be that:
> - critical interrupts are NOT blocked
> - you/your hardware uses critical interrupts for certain
> peripherals/timer or other stuff.
> If you would reveal more inforamtion on the hardware you are using, we
> might get more insight!
Hi Thomas,
In cpu.h, I see the following for _CPU_ISR_Disable:
#if 0
#define _CPU_ISR_Disable( _isr_cookie ) \
{ register unsigned int _disable_mask = _PPC_MSR_DISABLE_MASK; \
_isr_cookie = 0; \
asm volatile (
"mfmsr %0" : \
"=r" ((_isr_cookie)) : \
"0" ((_isr_cookie)) \
asm volatile (
"andc %1,%0,%1" : \
"=r" ((_isr_cookie)), "=&r" ((_disable_mask)) : \
"0" ((_isr_cookie)), "1" ((_disable_mask)) \
asm volatile (
"mtmsr %1" : \
"=r" ((_disable_mask)) : \
"0" ((_disable_mask)) \
#endif
_isr_cookie = 0; \
asm volatile ( \
"mfmsr %0; andc %1,%0,%1; mtmsr %1" : \
"=&r" ((_isr_cookie)), "=&r" ((_disable_mask)) : \
#endif
Looks like one method didn't work, so it was '#if 0' out.
_PPC_MSR_DISABLE_MASK is defined as:
#define PPC_MSR_ME 0x000001000 /* bit 19 - machine check enable */
#define PPC_MSR_EE 0x000008000 /* bit 16 - external interrupt enable
#if (PPC_HAS_RFCI)
#define PPC_MSR_CE 0x000020000 /* bit 14 - critical interrupt enable
#else
#define PPC_MSR_CE 0x000000000 /* bit 14 - critical interrupt enable
#endif
#define PPC_MSR_DISABLE_MASK (PPC_MSR_ME|PPC_MSR_EE|PPC_MSR_CE)
PPC_HAS_RFCI is defined as 1.
I am using the IBM STB025xx Digital set top box integrated controller, with
a PowerPC 405.
Hope this helps.
Nick
