Error while compiling libtecla
Daron Chabot daron.chabot at gmail.com
Mon Jun 7 11:33:44 UTC 2010
You need to set the environment variable RTEMS_MAKEFILE_PATH.
For example, using the pc386 BSP on my laptop:
djc at TooLBox--> export RTEMS_MAKEFILE_PATH=/opt/rtems/i386-rtems/pc386
-- dc
On Mon, Jun 7, 2010 at 7:26 AM, Gokul Sudhakaran <gsknvk at gmail.com> wrote:
> Hi
> I tried to compile libtecla addon for rtems by the method mentioned in
> README file in rtemsaddon folder.
> I got the following error output
> [root at GSK libtecla]# make -f ../RTEMS_Makefiles/Makefile.libtecla
> ../RTEMS_Makefiles/Makefile.common:8: /Makefile.inc: No such file or
> directory
> ../RTEMS_Makefiles/Makefile.common:10: /make/leaf.cfg: No such file or
> directory
> make: *** No rule to make target `/make/leaf.cfg'.  Stop.
> Can someone help me with this?
> Regards
> Gokul
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100607/21e0accc/attachment-0001.html>
