5KHz acquisition control
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Jun 7 23:43:47 UTC 2010
On 06/07/2010 06:29 PM, Eric Norum wrote:
> Indeed.
> I suspect that many of us expressing concern about kHz and up system
> clock rates are showing our age -- we used 50 Hz to 100 Hz system
> clocks back in the days of MVME167 cards (25 MHz 68040). Machines
> are a lot faster now -- perhaps a 5 kHz clock is not unreasonable
> nowadays.
As an experiment a few years ago, I wanted to see how low
the clock tick could go on a gen5200 PPC (~400Mhz 603e core
as I recall). It could set the tick at 5 microseconds and ticker
still ran. Much below that and the system quit making forward
progress.
Jennifer and I have ran less modest 603e systems at either
250 or 500 microsecond ticks in order to poll ~10 serial
ports on every tick. We had greater serial throughput polling.
No noticeable impact on the ~40 tasks in the application
using either individual UART interrupts or polling.
Given a sufficiently fast processor, 5Khz shouldn't be a problem.
But whether this works or not is a balancing act. You could
do too much work per ISR or at the task level and the mix
is unsustainable. But given a little care, it should work
with no trouble.
And Till.. I have recommended 1 millisecond ticks for at least
10 years. Each on the ERC32, it isn't that much load. And it
gets rid of a LOT of tick rounding issues on delays and timeouts. :)
--joel
> On Jun 7, 2010, at 3:18 PM, Till Straumann wrote:
>> Not sure. Having a higher resolution system clock can be quite useful
>> since it allows you to use finer-grained timeouts (on semaphores,
>> queues, sockets, ...)
>> or RTEMS timers etc. which can be desirable.
>> I have started to use a 1kHz clock by default on our MVME6100 boards
>> (1GHz powerpc) without noticeable impact on CPU load.
>> -- Till
>> On 06/07/2010 05:00 PM, Daron Chabot wrote:
>>> Matt,
>>> I've used a 455 MHz Pentium 3 interrupting at over 20 kHz as part of
>>> a VME-based data acquisition system.
>>> I agree with Robert: if you can generate interrupts at the frequency
>>> you need, _without_ using system's "ticks", that's the better
>>> approach. Hopefully your ADC hardware can generate interrupts upon
>>> conversion, or upon a "high-water-mark", or something similar...
>>> If that's not an option, you may be able to use one of the spare
>>> timers on the i8254 chip (if your system is so equipped).
>>> -- dc
>>> On Mon, Jun 7, 2010 at 4:23 PM, Robert Deschambault
>>> <robert.deschambault at gmail.com
>>> <mailto:robert.deschambault at gmail.com>> wrote:
>>> Hi,
>>> In my opinion, I wouldn't run the RTEMS with a clock tick like
>>> that, I would find a way to generate an external interrupt based
>>> on a hardware timer. I have successfully run RTEMS on a 40 MHz
>>> LEON2, with no changes to the RTEMS clock ticks, to accept a 16
>>> KHz interrupt signal for a fuzzy logic control loop to control a
>>> gimbal. Worked very well.
>>> On Mon, Jun 7, 2010 at 4:12 PM, Matt Rippa <mrippa at gemini.edu
>>> <mailto:mrippa at gemini.edu>> wrote:
>>> Hi -
>>> I would like to know your thoughts regarding common
>>> practices for an RTEMS system requiring a 5 KHz sample rate.
>>> The hardware is 600MHz i386/PC-104 based. Reading through
>>> the RTEMS C users guide the Rate Monotonic Scheduler appears
>>> to be what I'm interested in. Basically I need to read
>>> inputs from hardware, filter and process results, then write
>>> outputs with a period of 200 us.
>>> I understand I can set the RTEMS system clock ticks to get
>>> this resolution. My question is, is this a common and
>>> recommend practice for this kind of sample rate? Or do
>>> people favor using on-board programmable interrupt timers
>>> for this purpose? Is using an external interrupt timer on
>>> the pci bus a common practice if your SBC doesn't provide
>>> any timers?
>>> Thanks for any input.
>>> -Matt Rippa
>>> rtems-users mailing list
>>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>> Bob Deschambault
>>> 6614 Astro Court, Mississauga
>>> Ontario, Canada L5N 7J2
>>> home: 905 824 7159
>>> cell: 416 457 7163
> Eric Norum
> wenorum at lbl.gov <mailto:wenorum at lbl.gov>
