5KHz acquisition control
    Peter Dufault
    dufault at hda.com
    Tue Jun  8 09:10:04 UTC 2010
On Jun 7, 2010, at 6:00 , Daron Chabot wrote:
> I agree with Robert: if you can generate interrupts at the frequency you need, _without_ using system's "ticks", that's the better approach. Hopefully your ADC hardware can generate interrupts upon conversion, or upon a "high-water-mark", or something similar...
Plus there's the temporal spectral purity you'll get triggering the conversions in hardware.  I've got an 8KHz application, the hardware synchronizes the sampling across four boards and then DMA's it to memory and I run off the DMA interrupt.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
