rtems with matlab autocode problems
João Rasta
freakforever at gmail.com
Wed Jun 16 16:40:25 UTC 2010
Yes, i have no warnings during compilation. To compile i use
sparc-rtems-gcc.
I can print from all the tasks except function calls that are declared in
the library functions. I even manualy created a test function in the library
just to print something and then exit(0) afterwards but still no luck. But
it is strange since i get no warnings or errors during compilation. This is
the output of the application, where "Load X" are successfully loaded
threads.
Load 1--
Load 2--
Load 3
Load 3
Load 4
Load 5
Start GNC on wrapper
¬ÖUf
¬ÖUf
Program exited normally.
I don't see why it doesn't work, it is just a printf(), same as in all other
tasks.
Best,
JM
On Wed, Jun 16, 2010 at 4:56 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
> On 06/16/2010 10:52 AM, João Rasta wrote:
>> Hi,
>> No, autocode requires the real-time workbench only, it is quite
>> straightforward to generate the code.
>> I didn't fully understood your question. Anyway, i have tried to compile
>> the application with gcc and runs fine on linux so it should run on rtems
>> with the apropriate modifications. However, when i printf("test\n") within
>> the library finction, it returns strange characters, which doesn't happen in
>> the function that calls the library function..
> Is it including stdio.h? I have seen some targets where if you don't the
> variable
> arguments stuff gets confused.
> Is the generated code warning free?
>> I suspect of a compilation flag/option i may be missing on the library. Do
>> you have any idea?
>> As long as it is compiled the same as the rest of the app, it should be
> ok.
> Also, i don't need any rtems primitives/configurations on the library
>> functions right? I'm assuimng It is enough to have the rtems configuration
>> on the "main" file.
>> Right.
> Can you print from other tasks?
> --joel
>> Best,
>> JM
>> On Wed, Jun 16, 2010 at 4:42 PM, Joel Sherrill <joel.sherrill at oarcorp.com<mailto:
>> joel.sherrill at oarcorp.com>> wrote:
>> On 06/16/2010 10:38 AM, João Rasta wrote:
>> Hi,
>> I'm having trouble running an rtems application that uses code
>> generated from matlab using autocode. It all goes well until a
>> function of this library is called: printfs return awkward
>> characters and then the application crashes.
>> I have seen references to this before. Is this hard to do? Are
>> there instructions?
>> Standard glue code, etc.
>> 1) Is there any obvious reason to why printfs of the autocode
>> generated functions are not working properly? They are
>> compiled with sparc-rtems-gcc, as the main code.
>> 2) Are there any special flags needed to be passed to the
>> compiler in order to link other libraries? Or some rtems
>> configuration..
>> Is there any chance it is printing floating point numbers from a
>> non-FP task?
>> Best,
>> JM
>> -- Joel Sherrill, Ph.D. Director of Research&
>> Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
> Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20100616/019c157e/attachment-0001.html>
