rtems with matlab autocode problems
Jiri Gaisler jiri at gaisler.com
Wed Jun 16 17:31:34 UTC 2010
Each task is allocated a certain amount of stack space - how much
have you allocated to your auto-code one? You might try the RTEMS
stack checker to detect a stack overflow ...
Jiri.
João Rasta wrote:
> How can i be sure?
> The fact is that if i read the contents of all the memory space with
> grmon, they are not zero.. And i have "washed" prior to load the
> application.
> Best,
> JM
> On Wed, Jun 16, 2010 at 6:11 PM, Jiri Gaisler <jiri at gaisler.com
> <mailto:jiri at gaisler.com>> wrote:
>     João Rasta wrote:
>     > Just an update:
>     > If i do fflush(stdout) inside the test function, the application
>     > crashes. Also, no matter what i put in printf, it allways prints the
>     > same characters, but it detects the \n correctly.. I don't see if this
>     > can be related to the compiler..
>     Sounds to me like you have blown the stack or run out of memory ...
>     Jiri.
>     > Best,
>     > JM
>     > On Wed, Jun 16, 2010 at 4:56 PM, Joel Sherrill
>     > <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>
>     <mailto:joel.sherrill at oarcorp.com>>> wrote:
>     >     On 06/16/2010 10:52 AM, João Rasta wrote:
>     >         Hi,
>     >         No, autocode requires the real-time workbench only, it is
>     quite
>     >         straightforward to generate the code.
>     >         I didn't fully understood your question. Anyway, i have
>     tried to
>     >         compile the application with gcc and runs fine on linux so it
>     >         should run on rtems with the apropriate modifications.
>     However,
>     >         when i printf("test\n") within the library finction, it
>     returns
>     >         strange characters, which doesn't happen in the function that
>     >         calls the library function..
>     >     Is it including stdio.h?  I have seen some targets where if you
>     >     don't the variable
>     >     arguments stuff gets confused.
>     >     Is the generated code warning free?
>     >         I suspect of a compilation flag/option i may be missing on the
>     >         library. Do you have any idea?
>     >     As long as it is compiled the same as the rest of the app, it
>     should
>     >     be ok.
>     >         Also, i don't need any rtems primitives/configurations on the
>     >         library functions right? I'm assuimng It is enough to have the
>     >         rtems configuration on the "main" file.
>     >     Right.
>     >     Can you print from other tasks?
>     >     --joel
>     >         Best,
>     >         JM
>     >         On Wed, Jun 16, 2010 at 4:42 PM, Joel Sherrill
>     <mailto:joel.sherrill at oarcorp.com> <mailto:joel.sherrill at oarcorp.com
>     <mailto:joel.sherrill at oarcorp.com>>>> wrote:
>     >            On 06/16/2010 10:38 AM, João Rasta wrote:
>     >                Hi,
>     >                I'm having trouble running an rtems application
>     that uses
>     >         code
>     >                generated from matlab using autocode. It all goes well
>     >         until a
>     >                function of this library is called: printfs return
>     awkward
>     >                characters and then the application crashes.
>     >            I have seen references to this before.  Is this hard to
>     do?  Are
>     >            there instructions?
>     >            Standard glue code, etc.
>     >                1) Is there any obvious reason to why printfs of
>     the autocode
>     >                generated functions are not working properly? They are
>     >                compiled with sparc-rtems-gcc, as the main code.
>     >                2) Are there any special flags needed to be passed
>     to the
>     >                compiler in order to link other libraries? Or some
>     rtems
>     >                configuration..
>     >            Is there any chance it is printing floating point
>     numbers from a
>     >            non-FP task?
>     >                Best,
>     >                JM
>     >            --     Joel Sherrill, Ph.D.             Director of
>     Research&
>     >          Development
>     >            joel.sherrill at OARcorp.com        On-Line Applications
>     Research
>     >            Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>     >              Support Available             (256) 722-9985
>     >     Joel Sherrill, Ph.D.             Director of Research&
>      Development
>     >     joel.sherrill at OARcorp.com        On-Line Applications Research
>     > _______________________________________________
>     > rtems-users mailing list
>     > rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     > http://www.rtems.org/mailman/listinfo/rtems-users
