rtems with matlab autocode problems
    Till Straumann
    strauman at slac.stanford.edu
    Wed Jun 16 17:31:45 UTC 2010
Can you post the offending code?
T.
On 06/16/2010 12:02 PM, João Rasta wrote:
> Just an update:
> If i do fflush(stdout) inside the test function, the application
> crashes. Also, no matter what i put in printf, it allways prints the
> same characters, but it detects the \n correctly.. I don't see if this
> can be related to the compiler..
> Best,
> JM
> On Wed, Jun 16, 2010 at 4:56 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     On 06/16/2010 10:52 AM, João Rasta wrote:
>         Hi,
>         No, autocode requires the real-time workbench only, it is
>         quite straightforward to generate the code.
>         I didn't fully understood your question. Anyway, i have tried
>         to compile the application with gcc and runs fine on linux so
>         it should run on rtems with the apropriate modifications.
>         However, when i printf("test\n") within the library finction,
>         it returns strange characters, which doesn't happen in the
>         function that calls the library function..
>     Is it including stdio.h?  I have seen some targets where if you
>     don't the variable
>     arguments stuff gets confused.
>     Is the generated code warning free?
>         I suspect of a compilation flag/option i may be missing on the
>         library. Do you have any idea?
>     As long as it is compiled the same as the rest of the app, it
>     should be ok.
>         Also, i don't need any rtems primitives/configurations on the
>         library functions right? I'm assuimng It is enough to have the
>         rtems configuration on the "main" file.
>     Right.
>     Can you print from other tasks?
>     --joel
>         Best,
>         JM
>         On Wed, Jun 16, 2010 at 4:42 PM, Joel Sherrill
>         <mailto:joel.sherrill at oarcorp.com>>> wrote:
>            On 06/16/2010 10:38 AM, João Rasta wrote:
>                Hi,
>                I'm having trouble running an rtems application that
>         uses code
>                generated from matlab using autocode. It all goes well
>         until a
>                function of this library is called: printfs return awkward
>                characters and then the application crashes.
>            I have seen references to this before.  Is this hard to do?
>          Are
>            there instructions?
>            Standard glue code, etc.
>                1) Is there any obvious reason to why printfs of the
>         autocode
>                generated functions are not working properly? They are
>                compiled with sparc-rtems-gcc, as the main code.
>                2) Are there any special flags needed to be passed to the
>                compiler in order to link other libraries? Or some rtems
>                configuration..
>            Is there any chance it is printing floating point numbers
>         from a
>            non-FP task?
>                Best,
>                JM
>            --     Joel Sherrill, Ph.D.             Director of
>         Research&  Development
>            joel.sherrill at OARcorp.com        On-Line Applications Research
>            Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>              Support Available             (256) 722-9985
>     Joel Sherrill, Ph.D.             Director of Research&  Development
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100616/31a26e91/attachment-0001.html>
