rtems with matlab autocode problems
José Marinho isep
jmsm at isep.ipp.pt
Wed Jun 16 18:17:07 UTC 2010
-D defines a macro it is the same as having #define XX in the source code
On 16 June 2010 18:48, João Rasta <freakforever at gmail.com> wrote:
> Yes, here goes
> // dummy printf test code
> int upa(void)
> int i = 0;
> for (i=0; i < 20; i++)
> printf("B\n");
> exit(0);
> And the result is:
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> ¬ÖUf
> Program exited normally. This same code works correctly if i put the
> function in the main code instead of the library code. I still have no idea
> of what can be causing this, any hints would be apreciated. Mabe a compiler
> flag is messing up the library code?
> The matlab autocode makefile generates some flags i don't recognize such as
> the DXXX:
> sparc-rtems-gcc -c -O3 -g3 -ffloat-store -fPIC -DUSE_RTMODEL -DMODEL=gnc
> -DRT -DNUMST=1 -DTID01EQ=0 -DNCSTATES=0 -DUNIX -DMT=0 -DHAVESTDI
> O -I. -I../../rtwlt/matlab/simulink/include
> -I../../rtwlt/matlab/extern/include -I../../rtwlt/matlab/rtw/c/src
> src/ext_mode/common -I. -I.. -I../../rtwlt/matlab/rtw/c/libsrc
> ../../rtwlt/matlab/rtw/c/src/rt_sim.c
> These flags are not used in the "main" code, for instance
> sparc-rtems-gcc -DLOGGING=1 -DLOGNOTORIETY=10 -I"../src"
> -I"../src/comms/packet_lib" -I"../src/shell" -I"../src/comms"
> -I"../model/gnc_linu
> x" -I../rtwlt/matlab/simulink/include -I../rtwlt/matlab/extern/include
> -I../rtwlt/matlab/rtw/c/src -I../rtwlt/matlab/rtw/c/src/ext_mode/comm
> on -I../rtwlt/matlab/rtw/c/libsrc -O2 -g -Wall -c -fmessage-length=0 -DRT
> -MMD -MP -MF"src/common.d" -MT"src/common.d" -o"src/common.o" ".
> ./src/common.c"
> Has anyone seen the DXX flags?
> Best,
> JM
> On Wed, Jun 16, 2010 at 6:31 PM, Till Straumann <
> strauman at slac.stanford.edu> wrote:
>> Can you post the offending code?
>> T.
>> On 06/16/2010 12:02 PM, João Rasta wrote:
>> Just an update:
>> If i do fflush(stdout) inside the test function, the application crashes.
>> Also, no matter what i put in printf, it allways prints the same characters,
>> but it detects the \n correctly.. I don't see if this can be related to the
>> compiler..
>> Best,
>> JM
>> On Wed, Jun 16, 2010 at 4:56 PM, Joel Sherrill <joel.sherrill at oarcorp.com
>> > wrote:
>>> On 06/16/2010 10:52 AM, João Rasta wrote:
>>>> Hi,
>>>> No, autocode requires the real-time workbench only, it is quite
>>>> straightforward to generate the code.
>>>> I didn't fully understood your question. Anyway, i have tried to compile
>>>> the application with gcc and runs fine on linux so it should run on rtems
>>>> with the apropriate modifications. However, when i printf("test\n") within
>>>> the library finction, it returns strange characters, which doesn't happen in
>>>> the function that calls the library function..
>>> Is it including stdio.h? I have seen some targets where if you don't the
>>> variable
>>> arguments stuff gets confused.
>>> Is the generated code warning free?
>>>> I suspect of a compilation flag/option i may be missing on the library.
>>>> Do you have any idea?
>>>> As long as it is compiled the same as the rest of the app, it should
>>> be ok.
>>> Also, i don't need any rtems primitives/configurations on the library
>>>> functions right? I'm assuimng It is enough to have the rtems configuration
>>>> on the "main" file.
>>>> Right.
>>> Can you print from other tasks?
>>> --joel
>>>> Best,
>>>> JM
>>>> On Wed, Jun 16, 2010 at 4:42 PM, Joel Sherrill <
>>>> joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>>>> On 06/16/2010 10:38 AM, João Rasta wrote:
>>>> Hi,
>>>> I'm having trouble running an rtems application that uses code
>>>> generated from matlab using autocode. It all goes well until a
>>>> function of this library is called: printfs return awkward
>>>> characters and then the application crashes.
>>>> I have seen references to this before. Is this hard to do? Are
>>>> there instructions?
>>>> Standard glue code, etc.
>>>> 1) Is there any obvious reason to why printfs of the autocode
>>>> generated functions are not working properly? They are
>>>> compiled with sparc-rtems-gcc, as the main code.
>>>> 2) Are there any special flags needed to be passed to the
>>>> compiler in order to link other libraries? Or some rtems
>>>> configuration..
>>>> Is there any chance it is printing floating point numbers from a
>>>> non-FP task?
>>>> Best,
>>>> JM
>>>> -- Joel Sherrill, Ph.D. Director of Research&
>>>> Development
>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>> Support Available (256) 722-9985
>>> Joel Sherrill, Ph.D. Director of Research& Development
>> rtems-users mailing list
>> rtems-users at rtems.orghttp://www.rtems.org/mailman/listinfo/rtems-users
José Marinho
URL: <http://lists.rtems.org/pipermail/users/attachments/20100616/337ebb63/attachment-0001.html>
