rtems with matlab autocode problems
João Rasta freakforever at gmail.com
Wed Jun 16 18:53:48 UTC 2010
Sorry but what do you mean by "check what the string parameter points to"? I
can insert the breakpoint but i don't understand what is the string
parameter.
Best,
JM
On Wed, Jun 16, 2010 at 7:15 PM, Jiri Gaisler <jiri at gaisler.com> wrote:
> Everything in RTEMS is a task, either the init task or created 'secondary'
> tasks. You might want to set CONFIGURE_INIT_TASK_STACK_SIZE to some higher
> value if your auto-code uses a lot of stack space ...
> But the proper way to debug this is to put a breakpoint on the offending
> printf, and check what the string parameter points to. If it is not your
> intended string ("B\n"), it might have been overwritten in memory. Put a
> watch point on the address and check when it is written. Alternatively,
> the pointer to the string might have been overwritten, which can be
> tracked by similar means ...
> Jiri.
> João Rasta wrote:
> > It is not a task, just a simple function call. I passed this call to the
> > first thing in the void POSIX_Init() and the same happens. No matter
> > what i pass to printf or puts it allways writes the same if this
> > function is implemented on the autocode *.c files..
> > Best,
> > JM
> > On Wed, Jun 16, 2010 at 6:31 PM, Jiri Gaisler <jiri at gaisler.com
> > <mailto:jiri at gaisler.com>> wrote:
> >     Each task is allocated a certain amount of stack space - how much
> >     have you allocated to your auto-code one? You might try the RTEMS
> >     stack checker to detect a stack overflow ...
> >     Jiri.
> >     João Rasta wrote:
> >     > How can i be sure?
> >     > The fact is that if i read the contents of all the memory space
> with
> >     > grmon, they are not zero.. And i have "washed" prior to load the
> >     > application.
> >     > Best,
> >     > JM
> >     > On Wed, Jun 16, 2010 at 6:11 PM, Jiri Gaisler <jiri at gaisler.com
> >     > <mailto:jiri at gaisler.com <mailto:jiri at gaisler.com>>> wrote:
> >     >     João Rasta wrote:
> >     >     > Just an update:
> >     >     > If i do fflush(stdout) inside the test function, the
> application
> >     >     > crashes. Also, no matter what i put in printf, it allways
> >     prints the
> >     >     > same characters, but it detects the \n correctly.. I don't
> >     see if this
> >     >     > can be related to the compiler..
> >     >     Sounds to me like you have blown the stack or run out of
> >     memory ...
> >     >     Jiri.
> >     >     > Best,
> >     >     > JM
> >     >     > On Wed, Jun 16, 2010 at 4:56 PM, Joel Sherrill
> >     >     > <joel.sherrill at oarcorp.com
> >     <mailto:joel.sherrill at oarcorp.com> <mailto:joel.sherrill at oarcorp.com
> >     <mailto:joel.sherrill at oarcorp.com>>
> >     <mailto:joel.sherrill at oarcorp.com>>>> wrote:
> >     >     >     On 06/16/2010 10:52 AM, João Rasta wrote:
> >     >     >         Hi,
> >     >     >         No, autocode requires the real-time workbench only,
> >     it is
> >     >     quite
> >     >     >         straightforward to generate the code.
> >     >     >         I didn't fully understood your question. Anyway, i
> have
> >     >     tried to
> >     >     >         compile the application with gcc and runs fine on
> >     linux so it
> >     >     >         should run on rtems with the apropriate
> modifications.
> >     >     However,
> >     >     >         when i printf("test\n") within the library finction,
> it
> >     >     returns
> >     >     >         strange characters, which doesn't happen in the
> >     function that
> >     >     >         calls the library function..
> >     >     >     Is it including stdio.h?  I have seen some targets where
> >     if you
> >     >     >     don't the variable
> >     >     >     arguments stuff gets confused.
> >     >     >     Is the generated code warning free?
> >     >     >         I suspect of a compilation flag/option i may be
> >     missing on the
> >     >     >         library. Do you have any idea?
> >     >     >     As long as it is compiled the same as the rest of the
> >     app, it
> >     >     should
> >     >     >     be ok.
> >     >     >         Also, i don't need any rtems
> >     primitives/configurations on the
> >     >     >         library functions right? I'm assuimng It is enough
> >     to have the
> >     >     >         rtems configuration on the "main" file.
> >     >     >     Right.
> >     >     >     Can you print from other tasks?
> >     >     >     --joel
> >     >     >         Best,
> >     >     >         JM
> >     >     >         On Wed, Jun 16, 2010 at 4:42 PM, Joel Sherrill
> >     <mailto:joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>
> >     <mailto:joel.sherrill at oarcorp.com>>>>> wrote:
> >     >     >            On 06/16/2010 10:38 AM, João Rasta wrote:
> >     >     >                Hi,
> >     >     >                I'm having trouble running an rtems
> application
> >     >     that uses
> >     >     >         code
> >     >     >                generated from matlab using autocode. It all
> >     goes well
> >     >     >         until a
> >     >     >                function of this library is called: printfs
> >     return
> >     >     awkward
> >     >     >                characters and then the application crashes.
> >     >     >            I have seen references to this before.  Is this
> >     hard to
> >     >     do?  Are
> >     >     >            there instructions?
> >     >     >            Standard glue code, etc.
> >     >     >                1) Is there any obvious reason to why printfs
> of
> >     >     the autocode
> >     >     >                generated functions are not working properly?
> >     They are
> >     >     >                compiled with sparc-rtems-gcc, as the main
> code.
> >     >     >                2) Are there any special flags needed to be
> >     passed
> >     >     to the
> >     >     >                compiler in order to link other libraries? Or
> >     some
> >     >     rtems
> >     >     >                configuration..
> >     >     >            Is there any chance it is printing floating point
> >     >     numbers from a
> >     >     >            non-FP task?
> >     >     >                Best,
> >     >     >                JM
> >     >     >            --     Joel Sherrill, Ph.D.             Director
> of
> >     >     Research&
> >     >     >          Development
> >     >     >            joel.sherrill at OARcorp.com        On-Line
> Applications
> >     >     Research
> >     >     >            Ask me about RTEMS: a free RTOS  Huntsville AL
> 35805
> >     >     >              Support Available             (256) 722-9985
> >     >     >     Joel Sherrill, Ph.D.             Director of Research&
> >     >      Development
> >     >     >     joel.sherrill at OARcorp.com        On-Line Applications
> >     Research
> >     >     >     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >     >     > _______________________________________________
> >     >     > rtems-users mailing list
> >     >     > rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> >     <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
> >     >     > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20100616/d184d071/attachment-0001.html>
