rtems with matlab autocode problems
Jiri Gaisler jiri at gaisler.com
Thu Jun 17 11:51:33 UTC 2010
Since you are using floating-point operands (%f8), you need to enable FPU support
in the Init task ....
Jiri.
João Rasta wrote:
> Well, i'm using regular printf. I would not point to the encoding since
> it allways prints the same thing no matter what i pass to printf().
> I removed the 3 optimization in the gcc flags and removed the other ones
> and the same problem occurs. If i remove the printf the application
> exits on the following instruction
> IU in error mode (tt = 0x2b)
>  4000ca8c  d127bfec   st  %f8, [%fp - 0x14]
> . I'm initializing rtems with:
> #define CONFIGURE_INIT
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
> #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE (300*1024)
> #define CONFIGURE_MAXIMUM_POSIX_THREADS             10
> #define CONFIGURE_MAXIMUM_POSIX_MUTEXES                10
> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES            5
> #define CONFIGURE_POSIX_INIT_THREAD_TABLE
> I think i have enough stack space.
> Also, if i point CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT  to a function
> declared on the autocode the printfs do not work well, which does not
> happen if i point it to a function declared on the main code.
> The autocode is compiled with sparc-rtems-gcc and a library libgnc.a is
> created which is then passed to the compiler at link time with -lgnc.
> The library is created with
> ar ruvs libgnc.a *.o
> Does it make sense that there may be a problem with the compiled .o's of
> the library? If so, how can its declared functions be messing up with
> memory operations and not on the main code? They use the same compiler..
> Best,
> JM
> On Thu, Jun 17, 2010 at 4:18 AM, Ralf Corsepius
> <ralf.corsepius at rtems.org <mailto:ralf.corsepius at rtems.org>> wrote:
>     On 06/16/2010 07:48 PM, João Rasta wrote:
>         Yes, here goes
>         // dummy printf test code
>         int upa(void)
>             int i = 0;
>             for (i=0; i<  20; i++)
>                 printf("B\n");
>             exit(0);
>         And the result is:
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>             ¬ÖUf
>         Program exited normally.
>     Hmm, I am seeing "4 characters per line" instead of "1 or 2
>     characters per line" as one would expect.
>     Are you sure your code uses the right printf? 4 chars instead of 1
>     could indicate using UTF8 or UTF16 encoding instead of ACSII.
>         sparc-rtems-gcc -c -O3 -g3 -ffloat-store -fPIC   -DUSE_RTMODEL
>         -DMODEL=gnc
>         -DRT -DNUMST=1 -DTID01EQ=0 -DNCSTATES=0 -DUNIX -DMT=0 -DHAVESTDI
>         O   -I. -I../../rtwlt/matlab/simulink/include
>         -I../../rtwlt/matlab/extern/include -I../../rtwlt/matlab/rtw/c/src
>         src/ext_mode/common -I. -I.. -I../../rtwlt/matlab/rtw/c/libsrc
>         ../../rtwlt/matlab/rtw/c/src/rt_sim.c
>     ... -O3 -g3 -ffloat-store -fPIC
>     certainly leave room for speculation on incompatibility.
>     -03 ... switches on dangerous optimizations
>     -ffloat-store ... could be incompatible to rtems-gcc/newlib
>     -fPIC ... unneeded, unused by the rtems-toolchains, unknown
>       side effects on rtems-gcc/newlib
>     Ralf
> rtems-users mailing list
> rtems-users at rtems.org
