rtems with matlab autocode problems
João Rasta
freakforever at gmail.com
Thu Jun 17 14:49:23 UTC 2010
I figured. I'll try -O2, thank you.
JM
On Thu, Jun 17, 2010 at 3:38 PM, Jiri Gaisler <jiri at gaisler.com> wrote:
> Setting -O0 is equal to wasting ~ 70% of the cpu performance.
> Just so you know ....
> Jiri.
> João Rasta wrote:
> > Dear all,
> > I have finally managed to solve this issue by using the following
> > compilation flags *only* on the autocode library:
> > OPT_OPTS = -O0 -g -fmessage-length=0
> > I suspect of the ffloat-store and O3 optimization flags placed on the
> > library makefile by default by matlab, and mabe my answer to Ralf was
> > affected by not touch'ing all the project files before compilation.
> > I'm extremely grateful for all your valuable help.
> > Best,
> > JM
> > On Thu, Jun 17, 2010 at 12:56 PM, Manuel Coutinho
> > <manuel.coutinho at edisoft.pt <mailto:manuel.coutinho at edisoft.pt>> wrote:
> > Hi
> > Are you sure you are using the correct baud rate to comunicate with
> > the board (using GRMON)?
> > Did you try different baud rates?
> > Regards
> > Manuel Coutinho
> > Software Engineer - Space
> > EDISOFT, S.A.
> > Rua Quinta dos Medronheiros - Lazarim
> > Apartado 382 Monte de Caparica
> > 2826-801 Caparica Portugal
> > Tel: (+351) 212 945 900
> > Fax: (+351) 212 945 999
> > *From:* rtems-users-bounces at rtems.org
> > <mailto:rtems-users-bounces at rtems.org>
> > [mailto:rtems-users-bounces at rtems.org
> > <mailto:rtems-users-bounces at rtems.org>] *On Behalf Of *João
> Rasta
> > *Sent:* Thursday, June 17, 2010 10:33 AM
> > *To:* Ralf Corsepius
> > *Cc:* rtems-users at rtems.com <mailto:rtems-users at rtems.com>
> > *Subject:* Re: rtems with matlab autocode problems
> > Well, i'm using regular printf. I would not point to the
> > encoding since it allways prints the same thing no matter what i
> > pass to printf().
> > I removed the 3 optimization in the gcc flags and removed the
> > other ones and the same problem occurs. If i remove the printf
> > the application exits on the following instruction
> > IU in error mode (tt = 0x2b)
> > 4000ca8c d127bfec st %f8, [%fp - 0x14]
> > . I'm initializing rtems with:
> > #define CONFIGURE_INIT
> > #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
> > #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE (300*1024)
> > #define CONFIGURE_MAXIMUM_POSIX_THREADS 10
> > #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 10
> > #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 5
> > #define CONFIGURE_POSIX_INIT_THREAD_TABLE
> > I think i have enough stack space.
> > Also, if i point CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT to a
> > function declared on the autocode the printfs do not work well,
> > which does not happen if i point it to a function declared on
> > the main code.
> > The autocode is compiled with sparc-rtems-gcc and a library
> > libgnc.a is created which is then passed to the compiler at link
> > time with -lgnc. The library is created with
> > ar ruvs libgnc.a *.o
> > Does it make sense that there may be a problem with the compiled
> > .o's of the library? If so, how can its declared functions be
> > messing up with memory operations and not on the main code? They
> > use the same compiler..
> > Best,
> > JM
> > On Thu, Jun 17, 2010 at 4:18 AM, Ralf Corsepius
> > <ralf.corsepius at rtems.org <mailto:ralf.corsepius at rtems.org>>
> wrote:
> > On 06/16/2010 07:48 PM, João Rasta wrote:
> > Yes, here goes
> > // dummy printf test code
> > int upa(void)
> > int i = 0;
> > for (i=0; i< 20; i++)
> > printf("B\n");
> > exit(0);
> > And the result is:
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > ¬ÖUf
> > Program exited normally.
> > Hmm, I am seeing "4 characters per line" instead of "1 or 2
> > characters per line" as one would expect.
> > Are you sure your code uses the right printf? 4 chars
> > instead of 1 could indicate using UTF8 or UTF16 encoding
> > instead of ACSII.
> > sparc-rtems-gcc -c -O3 -g3 -ffloat-store -fPIC
> > -DUSE_RTMODEL -DMODEL=gnc
> > -DRT -DNUMST=1 -DTID01EQ=0 -DNCSTATES=0 -DUNIX -DMT=0
> > -DHAVESTDI
> > O -I. -I../../rtwlt/matlab/simulink/include
> > -I../../rtwlt/matlab/extern/include
> > -I../../rtwlt/matlab/rtw/c/src
> > src/ext_mode/common -I. -I..
> > -I../../rtwlt/matlab/rtw/c/libsrc
> > ../../rtwlt/matlab/rtw/c/src/rt_sim.c
> > ... -O3 -g3 -ffloat-store -fPIC
> > certainly leave room for speculation on incompatibility.
> > -03 ... switches on dangerous optimizations
> > -ffloat-store ... could be incompatible to rtems-gcc/newlib
> > -fPIC ... unneeded, unused by the rtems-toolchains, unknown
> > side effects on rtems-gcc/newlib
> > Ralf
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20100617/83fdd21d/attachment-0001.html>
