rtems with matlab autocode problems
Jiri Gaisler jiri at gaisler.com
Thu Jun 17 15:29:24 UTC 2010
At -O3, some versions of gcc will use %f registers to pass
integer parameters. This will cause a trap if RTEMS_FLOATING_POINT
is not set ...
Jiri.
João Rasta wrote:
> I'm not sure what could have cause the pattern. I would say a memory
> overwrite as already suggested but i'm still not aware of its source.
> Update:
> No problems with -O2.
> I also included the RTEMS_FLOATING_POINT as instructed by Jiri and
> everything goes well.
> Best,
> JM
> On Thu, Jun 17, 2010 at 4:11 PM, Andrei Chichak <groups at chichak.ca
> <mailto:groups at chichak.ca>> wrote:
>     Just an observation:
>     The pattern that is being printed has the hex values AA 99 55 66.
>     First, it's pretty odd that all of the nybbles are the same in each
>     byte. Next, the first and third bytes are complements of each other
>     as are the second and fourth.
>     This looks like a test pattern.
>     Andrei
>     On 2010-June-16, at 11:48 AM, João Rasta wrote:
>>     Yes, here goes
>>     // dummy printf test code
>>     int upa(void)
>>         int i = 0;
>>         for (i=0; i < 20; i++)
>>             printf("B\n");
>>         exit(0);
>>     And the result is:
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>         ¬ÖUf
>>     Program exited normally. This same code works correctly if i put
>>     the function in the main code instead of the library code. I still
>>     have no idea of what can be causing this, any hints would be
>>     apreciated. Mabe a compiler flag is messing up the library code?
>>     The matlab autocode makefile generates some flags i don't
>>     recognize such as the DXXX:
>>     sparc-rtems-gcc -c -O3 -g3 -ffloat-store -fPIC   -DUSE_RTMODEL
>>     -DMODEL=gnc -DRT -DNUMST=1 -DTID01EQ=0 -DNCSTATES=0 -DUNIX -DMT=0
>>     -DHAVESTDI
>>     O   -I. -I../../rtwlt/matlab/simulink/include
>>     -I../../rtwlt/matlab/extern/include -I../../rtwlt/matlab/rtw/c/src
>>     src/ext_mode/common -I. -I.. -I../../rtwlt/matlab/rtw/c/libsrc
>>     ../../rtwlt/matlab/rtw/c/src/rt_sim.c
>>     These flags are not used in the "main" code, for instance
>>     sparc-rtems-gcc  -DLOGGING=1 -DLOGNOTORIETY=10 -I"../src"
>>     -I"../src/comms/packet_lib" -I"../src/shell" -I"../src/comms"
>>     -I"../model/gnc_linu
>>     x" -I../rtwlt/matlab/simulink/include
>>     -I../rtwlt/matlab/extern/include -I../rtwlt/matlab/rtw/c/src
>>     -I../rtwlt/matlab/rtw/c/src/ext_mode/comm
>>     on -I../rtwlt/matlab/rtw/c/libsrc   -O2 -g -Wall -c
>>     -fmessage-length=0 -DRT -MMD -MP -MF"src/common.d"
>>     -MT"src/common.d" -o"src/common.o" ".
>>     ./src/common.c"
>>     Has anyone seen the DXX flags?
>>     Best,
>>     JM
>>     On Wed, Jun 16, 2010 at 6:31 PM, Till Straumann
>>     <strauman at slac.stanford.edu <mailto:strauman at slac.stanford.edu>>
>>     wrote:
>>         Can you post the offending code?
>>         T.
>>         On 06/16/2010 12:02 PM, João Rasta wrote:
>>>         Just an update:
>>>         If i do fflush(stdout) inside the test function, the
>>>         application crashes. Also, no matter what i put in printf, it
>>>         allways prints the same characters, but it detects the \n
>>>         correctly.. I don't see if this can be related to the compiler..
>>>         Best,
>>>         JM
>>>         On Wed, Jun 16, 2010 at 4:56 PM, Joel Sherrill
>>>         <joel.sherrill at oarcorp.com
>>>         <mailto:joel.sherrill at oarcorp.com>> wrote:
>>>             On 06/16/2010 10:52 AM, João Rasta wrote:
>>>                 Hi,
>>>                 No, autocode requires the real-time workbench only,
>>>                 it is quite straightforward to generate the code.
>>>                 I didn't fully understood your question. Anyway, i
>>>                 have tried to compile the application with gcc and
>>>                 runs fine on linux so it should run on rtems with the
>>>                 apropriate modifications. However, when i
>>>                 printf("test\n") within the library finction, it
>>>                 returns strange characters, which doesn't happen in
>>>                 the function that calls the library function..
>>>             Is it including stdio.h?  I have seen some targets where
>>>             if you don't the variable
>>>             arguments stuff gets confused.
>>>             Is the generated code warning free?
>>>                 I suspect of a compilation flag/option i may be
>>>                 missing on the library. Do you have any idea?
>>>             As long as it is compiled the same as the rest of the
>>>             app, it should be ok.
>>>                 Also, i don't need any rtems
>>>                 primitives/configurations on the library functions
>>>                 right? I'm assuimng It is enough to have the rtems
>>>                 configuration on the "main" file.
>>>             Right.
>>>             Can you print from other tasks?
>>>             --joel
>>>                 Best,
>>>                 JM
>>>                 On Wed, Jun 16, 2010 at 4:42 PM, Joel Sherrill
>>>                 <mailto:joel.sherrill at oarcorp.com>>> wrote:
>>>                    On 06/16/2010 10:38 AM, João Rasta wrote:
>>>                        Hi,
>>>                        I'm having trouble running an rtems
>>>                 application that uses code
>>>                        generated from matlab using autocode. It all
>>>                 goes well until a
>>>                        function of this library is called: printfs
>>>                 return awkward
>>>                        characters and then the application crashes.
>>>                    I have seen references to this before.  Is this
>>>                 hard to do?  Are
>>>                    there instructions?
>>>                    Standard glue code, etc.
>>>                        1) Is there any obvious reason to why printfs
>>>                 of the autocode
>>>                        generated functions are not working properly?
>>>                 They are
>>>                        compiled with sparc-rtems-gcc, as the main code.
>>>                        2) Are there any special flags needed to be
>>>                 passed to the
>>>                        compiler in order to link other libraries? Or
>>>                 some rtems
>>>                        configuration..
>>>                    Is there any chance it is printing floating point
>>>                 numbers from a
>>>                    non-FP task?
>>>                        Best,
>>>                        JM
>>>                    --     Joel Sherrill, Ph.D.             Director
>>>                 of Research&  Development
>>>                    joel.sherrill at OARcorp.com
>>>                 <mailto:joel.sherrill at OARcorp.com>        On-Line
>>>                 Applications Research
>>>                    Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>                      Support Available             (256) 722-9985
>>>             Joel Sherrill, Ph.D.             Director of Research&
>>>              Development
>>>         _______________________________________________
>>>         rtems-users mailing list
>>>         rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>>         http://www.rtems.org/mailman/listinfo/rtems-users
