Unexpected trap(0 x4) ... fp disabled
Jiri Gaisler
jiri at gaisler.com
Wed Jun 23 22:20:42 UTC 2010
The trace shows a normal exit by trapping to a system call
(ta 0) with %g1 = 1. This is how SPARC/RTEMS programs normally
exits:
> 4290658 4006d2ac mov 1, %g1 [00000001]
> 4290659 4006d2b0 ta 0x0 [trapped] <= sys call
> 4290665 40000800 mov %psr, %l0 [f3400fc6]
> 4290666 40000804 sethi %hi(0x4006fc00), %l4 [4006fc00]
> 4290667 40000808 jmp %l4 + 0x2e4 [40000808]
> 4290668 4000080c mov 128, %l3 [00000080]
> 4290671 4006fee4 cmp %g1, 2 [ffffffff]
> 4290691 4006fee8 bne 0x4006fefc [00000000]
> 4290692 4006feec or %l0, 0xf00, %l4 [f3400fc6]
> 4290693 4006fefc cmp %g1, 3 [fffffffe]
> 4290706 4006ff00 bne 0x4006ff18 [00000000]
> 4290707 4006ff04 and %i0, 0xf00, %l4 [00000900]
> 4290714 4006ff18 ta 0x0 [trapped] <= HALT
Did you get the FPU exception message on the screen
during this run too? If so, put a breakpoint on 0x40000040
which is where the FPU-disabled trap handler lives. If the
breakpoint is hit, then post the instruction trace from that
location.
> grlib> stack
> stack pointer: 0x4ffffff0
> I didn’t see a way to check the stack size to see if it had been overrun.
The grmon stack pointer just indicates how much memory grmon thinks
your system has. In RTEMS, each task has an allocated stack, typically
4 - 8 Kbyte. This applies also for the INIT task, in which context
you are probably executing. If your autocode uses more (most likely),
then you must allocate more stack when the task is created. RTEMS is
not unix where an infinite amount of stack can be added automatically ... :-)
Refer to the RTEMS docs or to this forum on how to define stack space
in RTEMS...
Jiri.
> Michael T. Gardner
> Sandia National Labs
> mtgardn at sandia.gov
> 505-844-1299
> rtems-users mailing list
> rtems-users at rtems.org
