Failed writes to block devices don't report an error
Chris Johns
chrisj at rtems.org
Wed Jun 23 23:12:14 UTC 2010
On 24/06/10 2:08 AM, Arnout Vandecappelle wrote:
> On Wednesday 23 June 2010 03:18:02, Chris Johns wrote:
>> I see us needing both of these. Further the 'write' has:
>> "[SIO] If the O_DSYNC bit has been set, write I/O operations
>> on the file descriptor shall complete as defined by synchronized
>> I/O data integrity completion."
>> This is an extension. I cannot find any further detail about the SIO
>> extensions but to me it makes sense that we look at a standards base way
>> of managing this. We have an AIO effort underway so we should consider
>> the O_DSYNC flag.
> Agreed, but that's a lot more effort as it requires support all over the
> filesystem.
It is not a small undertaking. I wanted to put on the record what we
should aim at and to justify the selection of 1.
> [snip]
>>> 1. Make sure rtems_bdbuf_sync() returns an error if the write fails.
>>> rtems_bdbuf_sync() is called when disks or files are sync'ed. It
>>> writes back a block and waits for the writeback to finish. Currently,
>>> it always returns successfully but we could put error detection code
>>> in here.
>> This would be good to have. I see it being needed which ever way we go.
>> I also see the following:
>> if (write(fd, buf, size) != size)
>> goto handle_error
>> if (sync_call(..)< 0)
>> goto handle_error
>> in an application could be a work around until a more standard approach
>> is made. I prefer this over the other suggestions.
> ...which is why I put it as the first one :-)
If you are using the DOSFS it may pay to check if it has hold of a
buffer that may not be flushed. I think there are paths that can result
in it holding a buffer. The sync call currently does not touch the file
systems.
