Building RTEMS: make install command error
Sebastian Huber
Mon Jun 28 08:24:52 UTC 2010
On 06/28/2010 10:14 AM, Christian Castellaro wrote:
> c:\programs\ti\bin\gmake.exe[1]: Entering directory `c:/home/rtems-4.9.4-psim/make'
> gmake[2]: Entering directory `c:/home/rtems-4.9.4-psim/make'
> gmake[2]: Nothing to be done for `install-exec-am'.
> test -z "/opt/rtems-4.9/make" || /bin/mkdir -p "/opt/rtems-4.9/make"
> 'test' is not recognized as an internal or external command,
> operable program or batch file.
Make sure the you use the correct MinGW/MSYS environment.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
