Axiom mcf5235BCC freezing
Alan Cudmore
Alan.P.Cudmore at nasa.gov
Wed Jun 30 17:04:42 UTC 2010
Thad,
I use these boards extensively and have no problems with RTEMS
freezing. I often leave one running in my office for days, if not
weeks and it seems stable.
I have used RTEMS 4.9.x, but I'm up to a fairly recent CVS version
right now with the 4.10 tools.
Somewhere in the 4.9.x release there was a problem with the code in
start.S on that board. Compare the code in libbsp/m68k/mcf5235/start/
start.S between your version and the latest CVS version.
I'm pretty sure this was added:
move.l #0x20000201, d0
move.l d0,(0x40000008) | set up 2nd RAMBAR to make 2nd
port avail to FEC
Otherwise, I cannot think of anything else that freezes the board. Do
you have a second board to try?
Also, I have not loaded via TFTP. I use BDM most of the time, then I
also have a modified flash build of RTEMS that I load in place of the
monitor that comes on the board.
Alan
On Jun 30, 2010, at 12:50 PM, Seeberger, Thad [USA] wrote:
> good day, I am new to RTEMS and learning, I built mcf5235 BSP with
> tests. Downloading with tftp. The Hello World test freezes as well
> as others. The ticker test gets to TA3 then freezes.
> Where should I go from here? I'm using rtems-4.9 tools on fedora 7
> installed with yum. The rtems is rtems 4.9.2
> Any pointers appreciated.
> Thanks
> Thad Seeberger
> NSWCDD
> 540 653 9279
> Thad Seeberger
> NSWCDD
> 540 653 9279
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100630/65c796e2/attachment-0001.html>
