Axiom mcf5235BCC freezing
    Seeberger, Thad [USA]
    seeberger_thad at bah.com
    Wed Jun 30 23:59:19 UTC 2010
Do you mean hardware reset or reset DBUG command. If I hardware reset how do I know jump location to start.
I'd like to try this.
Thanks
Thad Seeberger
NSWCDD
540 653 9279
________________________________________
From: rtems-users-bounces at rtems.org [rtems-users-bounces at rtems.org] On Behalf Of Andrei Chichak [groups at chichak.ca]
Sent: Wednesday, June 30, 2010 1:25 PM
To: RTEMS List
Subject: Re: Axiom mcf5235BCC freezing
I found that after downloading using tftp in dBUG you have to hit reset, then run the app. The SDRAM doesn't get cleared with the reset.
My testing was on a cmm5235 with 4.9.4.
Andrei
On 2010-June-30, at 10:50 AM, Seeberger, Thad [USA] wrote:
> good day, I am new to RTEMS and learning, I built mcf5235 BSP with tests. Downloading with tftp. The Hello World test freezes as well as others. The ticker test gets to TA3 then freezes.
> Where should I go from here? I'm using rtems-4.9 tools on fedora 7 installed with yum. The rtems is rtems 4.9.2
> Any pointers appreciated.
rtems-users mailing list
rtems-users at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-users
