Simple Line Editor
Till Straumann
strauman at slac.stanford.edu
Tue Mar 2 17:46:14 UTC 2010
The port that comes with 'cexp' has a modified 'configure.in' which
disables that stuff
if the host-os is RTEMS.
T.
Eric Norum wrote:
> It's already an 'add-on' package but I think that it's not being built as Till suggested. I ran the script to build this for RTEMS and the Makefile ends up with:
> DEFINES = -DUSE_TERMINFO=1 -DHAVE_TERM_H=1 -DHAVE_CURSES_H=1 -DHAVE_SELECT=1
> I don't see any 'configure' option to control the termcap/terminfo/ANSI setting. Is explicit editing of the generated Makefile the only way to get rid of the
> -DUSE_TERMINFO?
> On Mar 2, 2010, at 8:23 AM, Joel Sherrill wrote:
>> On 03/02/2010 09:59 AM, Till Straumann wrote:
>>> Eric Norum wrote:
>>>> This looks like an interesting project. As the web page says,
>>>> functionality somewhat like readline would be very useful.
>>>> The one big requirement is that the code be reentrant to allow for
>>>> multiple ssh or telnet 'logins' to the RTEMS machine. This is
>>>> currently the major shortcoming in readline (and the similar 'tecla'
>>>> project) since they rely on the termcap library which is non-reentrant.
>>> You can build 'tecla' without using curses, ncurses or termcap and you get a
>>> very nice, re-entrant line editor (assumes/supports an ANSI terminal only).
>>> FWIW
>> That looks like a nice alternative. Any idea on how big the
>> resulting library is?
>> It might be better to
>> (1) verify this meets our technical requirements,
>> (2) port it.
>> (3) get it to build as part of cpukit.
>> (4) change shell/monitor methods to use it via providing
>> new implementations of what they call.
>> There is no point in reinventing the wheel.
>> --joel
>>> -- Till
>>>> A way to limit the scope to make the project more tractable would be
>>>> to support only the ANSI terminal control sequences. This isn't that
>>>> big a restriction nowadays when a 'terminal' is likely an emulation
>>>> program running on another computer.
>>>> On Feb 20, 2010, at 8:22 AM, Gokul Sudhakaran wrote:
>>>>> Hi
>>>>> I recently installed rtems on my system and have been browsing
>>>>> through some of the open projects in the rtems wiki pages. I am
>>>>> interested in implementing the Simple Line Editor project.
>>>>> (http://www.rtems.com/wiki/index.php/SimpleLineEditor).
>>>>> I would appreciate it if someone could help me in getting a clear
>>>>> idea about the problem, any examples or sites that i could refer.
>>>>> Regards
>>>>> Gokul
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.org<mailto:rtems-users at rtems.org>
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>> Eric Norum
>>>> wenorum at lbl.gov<mailto:wenorum at lbl.gov>
>> Joel Sherrill, Ph.D. Director of Research& Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
