Loading application data
mike
antispam21 at verizon.net
Wed Mar 17 16:06:24 UTC 2010
Yes, there are. The default is 128 for a max file size of 4,329,344 bytes.
See /opt/rtems/rtems-4.8.1/cpukit/libfs/src/imfs/imfs.h:
* Setting IMFS_MEMFILE_BYTES_PER_BLOCK to different values has a
significant
* impact on the maximum file size supported as well as the amount of
* memory wasted due to internal file fragmentation. The following
* is a list of maximum file sizes based on various settings
* max_filesize with blocks of 16 is 1,328
* max_filesize with blocks of 32 is 18,656
* max_filesize with blocks of 64 is 279,488
* max_filesize with blocks of 128 is 4,329,344
* max_filesize with blocks of 256 is 68,173,568
* max_filesize with blocks of 512 is 1,082,195,456
Leontie Eugen wrote:
> Is there a limitation on the file sizes of IMFS ?
> I successfully used the method below for(multiple)small files, but I get errors if I try to create a file that is larger than 512k or so.
> This is not the problem of untar.
> ex.
> FILE * fp= fopen("/xxx","w");
> n=fwrite(ptr,1, 623616,fp);
> the operation only writes up to a point. n is 558080.
> ( I am working with the Sparc64 port so I am just trying to see if this might be a 32/64 bit issue, an insufficient sizing of some memory region or just a IMFS limitation)
> Eugen
> --- On Wed, 3/10/10, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> From: Joel Sherrill <joel.sherrill at oarcorp.com>
>> Subject: Re: Loading application data
>> To: "Eric Norum" <wenorum at lbl.gov>
>> Cc: "RTEMS" <rtems-users at rtems.org>
>> Date: Wednesday, March 10, 2010, 8:08 PM
>> On 03/10/2010 11:59 AM, Eric Norum
>> wrote:
>>> I do this for my standalone EPICS applications by
>> concatenating the tar file at the end of the bootstrap
>> flash. I then set up the IMFS with the tar image
>> during my application startup with the following code.
>> The salient routine is rtems_tarfs_load. You'll
>> have to figure out some way of determining the value of the
>> tar image in memory, but once you can do that
>> rtems_tarfs_load() takes care of the rest.
>> The network-demos httpd does this. It is fairly
>> straightforward.
>> --joel
>>> static int
>>> initialize_local_filesystem(char **argv)
>>> extern char _DownloadLocation[]
>> __attribute__((weak));
>>> extern char _FlashBase[]
>>> extern char _FlashSize[]
>>> if (_FlashSize&&
>> (_DownloadLocation || _FlashBase)) {
>>> extern char
>> _edata[];
>>> size_t flashIndex =
>> _edata - _DownloadLocation;
>>> char *header =
>> _FlashBase + flashIndex;
>>> if (memcmp(header +
>> 257, "ustar ", 8) == 0) {
>>> int
>> fd;
>>> printf
>> ("***** Unpack in-memory file system (IMFS) *****\n");
>>> if
>> (rtems_tarfs_load("/", (unsigned char *)header,
>> (size_t)_FlashSize - flashIndex) != 0) {
>> printf("Can't unpack tar filesystem\n");
>> return 0;
>>> .........do whatever you want
>> with the IMFS at this point.........
>>> return 0;
>>> On Mar 10, 2010, at 9:39 AM, Gedare Bloom wrote:
>>>> Hi,
>>>> I'm trying to figure out what is the most portable
>> (with respect to
>>>> BSP) way to get file-based data in to an
>> application. I can't use
>>>> network or ATA-type disk drive. I've had
>> some thoughts, and was
>>>> hoping someone might have faced this type of
>> problem before me. My
>>>> motivation is to do benchmarking of RTEMS systems
>> with respect to
>>>> compute and memory usage. My particular board does
>> not support hard
>>>> drive or network I/O -- and in general I would
>> like to have a portable
>>>> set of benchmarks that any other RTEMS user can
>> use. Most of the
>>>> benchmarks that I'm looking at use file i/o to get
>> parameters for
>>>> execution.
>>>> I was looking at the various filesystems, and was
>> intrigued by the
>>>> IMFS, The Wiki says the following: "After an
>> application restart you
>>>> will need to construct its contents. RTEMS
>> provides some supporting
>>>> calls for this plus there is the ability to tar
>> files into it." What
>>>> is that bit about the ability to tar files into
>> it? Does this require
>>>> network support?
>>>> I could try to use a RAM disk and somehow
>> interface that with an RTEMS
>>>> filesystem. Is there any support for this in
>> RTEMS? Any idea how I
>>>> would get RTEMS to know where to find the RAM
>> disk?
>>>> My last option is to convert the files that I have
>> in to arrays of
>>>> data (compressed binary/hex or ascii strings) that
>> are stored as part
>>>> of the application. This would definitely be the
>> most portable way to
>>>> get the data in to applications, but involves a
>> bit of work
>>>> translating the files to something usable by the
>> application.
>>>> Maybe someone has done something similar -- I
>> really just need a good,
>>>> portable way to get application data in to RTEMS.
>> Although the data is
>>>> currently organized in Unix files, if there are
>> some tools to convert
>>>> files in to some other format that makes it easy
>> to place in memory
>>>> alongside the RTEMS application, it would probably
>> satisfy my
>>>> constraints.
>>>> Also, if anyone else is interested in such a set
>> of benchmarks, let me
>>>> know and I can keep you appraised of my progress.
>>>> Thanks,
>>>> Gedare
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>> Joel Sherrill, Ph.D.
>> Director of Research&
>> Development
>> joel.sherrill at OARcorp.com
>> On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available
>> (256) 722-9985
