Building the newest RTEMS error: Invalid BSP
Mon Mar 29 14:10:45 UTC 2010
On 03/29/2010 08:47 AM, smy wrote:
> autoconf version2.65   automake version1.11.
> I build rtems 4.9.4 successfully but failed in the current cvs version.
> Besides, I finished the things " Prove You can Work On RTEMS"
> required, can somebody be so kind to tell me where the diff and
> snapshot to be sent ?
Just sent it offlist to me.  And then add yourself to the table
in http://www.rtems.com/wiki/index.php/RTEMSSummerOfCode
You will need an account on the wiki to add yourself.
> Thank you a lot!
We try.  There are just so many variations.  We encourage people
to stick to a few platforms so we can help better.
As Ralf pointed out, there is only so much we can do.
--joel
> 2010/3/29 Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>>
>     On 03/29/2010 07:44 AM, smy wrote:
>             You lost steps in the configure process somewhere. Every
>             BSP is built every day now.  Plus you are looking at 4.9.4.
>             We will need more information to help you.  What host,
>             configure command, "echo $PATH", etc.  You just said
>             "it's broken" and we can't see your screen.
>             FWIW you need to build the CVS head as part of the
>             GSoC Getting Started but since you have started
>             with 4.9.4, let's finish that first.
>             --joel
>         Thank you for replying. :)
>         My steps are:
>         1. cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co
>         -rrtems-x-y-branch rtems
>             cd rtems
>             ./bootstrap
>     What version of autoconf and automake do you have?
>     RTEMS has to be bootstrapped with the right versions.
>     4.9 uses these
>     -bash-4.0$ rpm -qf /opt/rtems-4.9/bin/autoconf
>     rtems-4.9-autoconf-2.62-4.fc12.noarch
>     -bash-4.0$ rpm -qf /opt/rtems-4.9/bin/automake
>     rtems-4.9-automake-1.10.3-1.fc12.noarch
>     It doesn't look like either has any patches.
>         2. mkdir rtems-build
>             cd rtems-build
>             ../rtems/configure --target=sparc-rtems -enable-rtemsbsp=sis
>         --enable-test=samples --disable-posix --disable-itron
>         --prefix=/home/smy/sparc-rtems
>     Since you built your own tools, did you apply the patches
>     in contrib/crossrpms/patches?  What --target did you use
>     on the tool configure. The expected target here is:
>     --target=sparc-rtems4.9
>         3. make&&  make install
>         configure: error: Invalid BSP
>         configure: error:
>         ../../../../../../../rtems/c/src/lib/libbsp/sparc/configure
>         failed for
>         lib/libbsp/sparc
>         make[2]: *** [sis] Error 1
>         make[2]: Leaving directory
>         `/home/smy/toolchain/rtems-build/sparc-rtems/c'
>         make[1]: *** [all-recursive] Error 1
>         make[1]: Leaving directory
>         make: *** [all-recursive] Error 1
>         Besides, the 'uname -a' result is 'Linux mort-desktop
>         2.6.24-26-generic
>         #1 SMP Tue Dec 1 18:37:31 UTC 2009 i686 GNU/Linux'
>         and
>         PATH='/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/smy/sparc-bin/bin'
>         where /home/smy/sparc-bin/bin contains the binutils and
>         cross-compiler.
>     What distribution is this?  Obviously you built your
>     own tools.
>     This looks suspiciously like a bootstrap and autotools
>     version issue.
>     Joel Sherrill, Ph.D.             Director of Research&  Development
>     joel.sherrill at OARcorp.com        On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>       Support Available             (256) 722-9985
