Coldfire uC5282 Question
Eric Norum wenorum at lbl.gov
Tue Mar 30 18:14:20 UTC 2010
That's the standard 'SCC' command (Set Condition Code) -- In everything from the 68000 on up.
From the programmer's guide:
Attributes:   Size = (Byte)
Description:	The specified condition code is tested. If the condition is true, the bits at the effective address are all set to one (i.e., $FF). Otherwise, the bits at the effective address are set to zeros (i.e., $00).
So,  'SF' would be 'Set On False' -- i.e. set never.   Another way to  'clear byte' I guess.
Kind of a corner case for the SCC instruction, but the emulator really should handle it!
On Mar 30, 2010, at 10:48 AM, Joel Sherrill wrote:
> Hi,
> I am running gcc testsuite on the qemu uC5282
> simulator.  I am getting a number of failures
> where qemu says an illegal instruction was
> encountered.  Can a coldfire person out there
> tell me whether this is qemu not supporting
> a valid coldfire instruction or this instruction
> should not be generated by gcc with the -mcpu=5282
> option
> [joel at rtbf64b gcc]$ m68k-rtems4.10-objdump -da zero-struct-2.x7 | grep -i "51 ca"
> [joel at rtbf64b gcc]$ m68k-rtems4.10-objdump -da zero-struct-2.x7 | grep -i "5186c"
>   5186c:    51ca               sf %d2
> $ uC5282 -i zero-struct-2.x7
> /users/joel/qemu-coverage/install/bin/qemu-system-m68k is /users/joel/qemu-coverage/install/bin/qemu-system-m68k
> qemu: fatal: Illegal instruction: 51ca @ 0005186c
> D0 = 00000000   A0 = 00063b98   F0 = 0000000000000000 (           0)
> D1 = 00000034   A1 = 00063186   F1 = 0000000000000000 (           0)
> D2 = 00000000   A2 = 00063b98   F2 = 0000000000000000 (           0)
> D3 = 000615e6   A3 = 00000000   F3 = 0000000000000000 (           0)
> D4 = 00000034   A4 = 00000000   F4 = 0000000000000000 (           0)
> D5 = 00000000   A5 = 00000000   F5 = 0000000000000000 (           0)
> D6 = 00000000   A6 = 2000ffcc   F6 = 0000000000000000 (           0)
> D7 = 00000000   A7 = 2000ffa0   F7 = 0000000000000000 (           0)
> PC = 00051864   SR = 2700 ----- FPRESULT =            0
> [joel at rtbf64b gcc]$ uC5282 zero-struct-2.x7^C
> Thanks.
> Joel Sherrill, Ph.D.             Director of Research&  Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>   Support Available             (256) 722-9985
> rtems-users mailing list
> rtems-users at rtems.org
Eric Norum
wenorum at lbl.gov
