_Thread_Dispatch_disable_level gone negative.
Leon Pollak leonp at plris.com
Wed May 5 08:52:30 UTC 2010
On Wednesday May 5 2010, Nick Thomas wrote:
> > Nick,
> > I think I had the similar problem, when 0xffffffff was the value of
> > comtrol variable - do not remember exactly its name, but it was
> > something in _Watchdog_.....
> > This was the problem in old version of RTEMS which is solved in upper
> > versions.
> > Joel pointed me to the corresponding PR number, but I do not remember
> > it
> > too...:-)
> > Anyway, you need to upgrade...:-((
> > This is what I finally did, although it cost me a lot of efforts...
> > Leon
> Hi Leon,
> There is a comment in cpukit\score\src\watchdoginsert.c, at about line 90.
> Inside the _Watchdog_Insert function.
> It's about the call to _ISR_Flash( level ); which is just below it.
> It says, "if you have problems, comment out _ISR_Flash."
> Is this the problem you are referring to?
I found the issue in the mail archive:
http://www.rtems.com/ml/rtems-users/2009/may/msg00048.html
Hope this helps.
Leon
