Support for authentication in ftpd
Arnout Vandecappelle
arnout at mind.be
Wed May 5 12:44:20 UTC 2010
Hoi all,
I finally got around to preparing the patches for adding authentication to
ftpd. I did use the rtems_shell_login_check_t function after all.
Attached are two patches. The first one just adds the authentication hook
and only gives access when authentication succeeds. The second one does the
same, but adds another hook that allows you to define access permissions per
(file,user) combination.
Comments are welcome.
Regards,
Arnout
On Wednesday 28 April 2010 14:13:19, Joel Sherrill wrote:
> On 04/28/2010 03:23 AM, Arnout Vandecappelle wrote:
> > Hoi all,
> > I'm going to add some form of authentication to ftpd. The idea is
> > that I'll add a hook function to the configuration that returns
> > permissions per file or directory on which an operation is executed.
> > It would be used instead of the global access configuration (with the
> > global access configuration as a fall-back).
> > Is anybody else interested? Any remarks or other approaches I should
> > consider?
> I think it would be a nice feature especially if it followed
> the format of the login plugin setup for telnetd. Then
> an authentication engine could work with either one.
> --joel
> > Regards,
> > Arnout
Arnout Vandecappelle arnout at mind be
Senior Embedded Software Architect +32-16-286540
Essensium/Mind http://www.mind.be
G.Geenslaan 9, 3001 Leuven, Belgium BE 872 984 063 RPR Leuven
LinkedIn profile: http://www.linkedin.com/in/arnoutvandecappelle
GPG fingerprint: 31BB CF53 8660 6F88 345D 54CC A836 5879 20D7 CF43
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20100505/0986b9a3/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20100505/0986b9a3/attachment-0001.bin>
